Is there any help needed with Russian translation review?
Transifex showing 90% translated but 40% reviewed.
https://www.transifex.com/discourse/discourse-org/translate/#ru/clientenyml/65594736?reviewed=no&q=unread
@techAPJ @meglio
thx
Hi Denis, thanks for raising this questions.
I’m reviewing the Russian translations.
Reviewing takes really lots of time, see why - it’s not just looks good, click “review”.
No need for rush as unreviewed translations are used as well by Discourse. So reviewing is more like making sure a translation is correct and you don’t need to get back to it anymore (until the context changes).
I tend to review only those translations that are 100% correct in the given context. Sometimes translating a term takes weeks of consulting people and looking at other community websites to find the best fit.
So if you wanna help with the translations, the best thing would be translating untranslated strings, taking into account everything outlined in the tips above. – Thanks!
Clear thanks. We are ready to fund some amount for freelance translator if needed to speedup.
