Is there support for custom topic field per Category?
Is there support custom topic fields by category that are operable?
One example would be to have an category whose topics require a date and then being able to sort the topics within the category by the new field?
Of course a plugin or some other customization can do it, but can you just use the built in extensibility to get there?
2 个赞
There is currently no facility for displaying custom topic fields.
Thanks. Would you guys consider adding such a feature? Seems like it would have wide applicability. Possible uses include:
Date/Time of event
Location
Price
Solved
Installed count (would take extra support - essentially having likes update a different field?)
Perhaps some of the code from the custom user fields support could be used.
Thanks!
I’d be interested in a feature like this. I’m planning to have a Discourse instance be the backbone of a plugin repository; each plugin would have a topic in a certain category with a field that can be set. An external frontend would then query the API for information from Discourse such as download link, version, and author.
Edit: I found this but it’s not clear how to use this. I’ve also been studying the tagging plugin but I have no idea how that works, I just want to be able to add a custom field to the json output of the topic.
3 个赞
对于我们的山羊奶酪市场,我会使用自定义主题字段。
我会选择“货币”格式,并在“主题视图”中添加“筛选”选项。
1 个赞
