Is this meant to happen when I run the rebuild command?
I’m Running Discourse on a DigitalOcean Droplet
I had to change my email settings in app.yml which I figured out how to do just fine but when I try to run the rebuild container command I see this:
Is that normal? If I follow these prompts will it destroy my Discourse forum, I spent ages setting it up today and backups seem to be broken:
[2018-02-05 21:13:56] Marking backup as running...
[2018-02-05 21:13:56] Making sure '/var/www/discourse/tmp/backups/default/2018-02-05-211355' exists...
[2018-02-05 21:13:56] Making sure '/var/www/discourse/public/backups/default' exists...
[2018-02-05 21:13:56] Pausing sidekiq...
[2018-02-05 21:13:56] Backup process was cancelled!
I’m completely lost, thanks in advance
That doesn’t make any sense at all. I thought that their one-click install did something that resembled a supported install, and that you’d see a message like that when you first logged in, not when you ran ./launcher.
If that’s what ./launcher does, then you may be on your own, as this does not look like a supported install.
When did you install it?
I used their one click install yesterday, even installed the Retort plugin without any issues, it let me rebuild it then but now it just goes to that message straight away. :confused:
EDIT: I have one error in the discourse admin logs.
TypeError: e.jqXHR.responseJSON.join is not a function
Url: http://www.vapingcommunity.co.uk/assets/application-2419cc98b7825aaca132b6a042338b1022877b8d183bb67ecd18f4b14525f307.js
Line: 5
Column: 24589
Window Location: http://www.vapingcommunity.co.uk/
I have the option of taking a snapshot on Digital Ocean, do you think it would be worth a try to do that and go through the above prompts just to see what happens?
It usually prints that message when you log in and you can just control-c to quite and then
cd /var/discourse
./launcher rebuild app
I know some ways that I’d fix it, but none are simple enough to explain here.
But sure, take a snap shot and see if you can fix it. If things get really bad you can step back to the snapshot.
Ill try that right now, thanks so much for your help
You are a Legend.. So here’s what I did.
Logged on via SSH
cd /var/discourse
The message came up, I used control-c and it just ran the rebuild :smile:
Thanks again, I was panicking as this is my second day using Discourse and doing anything command based. :+1:
@pfaffman Sorry if this in the wrong place but can I just add that after the rebuild I tried a backup from the admin section, it failed but I got a solid error log and a notification:
[2018-02-05 23:05:17] Marking backup as running...
[2018-02-05 23:05:17] Making sure '/var/www/discourse/tmp/backups/default/2018-02-05-230517' exists...
[2018-02-05 23:05:17] Making sure '/var/www/discourse/public/backups/default' exists...
[2018-02-05 23:05:17] Pausing sidekiq...
[2018-02-05 23:05:17] Waiting for sidekiq to finish running jobs...
[2018-02-05 23:05:17] Backup process was cancelled!
[2018-02-05 23:05:17] Notifying 'vapingcommunity' of the end of the backup...
[2018-02-05 23:05:23] Removing old backups...
[2018-02-05 23:05:23] Cleaning stuff up...
[2018-02-05 23:05:23] Removing '.tar' leftovers...
[2018-02-05 23:05:23] Unpausing sidekiq...
[2018-02-05 23:05:23] Marking backup as finished...
[2018-02-05 23:05:23] Finished!
So can we assume that a rebuild somewhat fixed the backup process or changed it in some way?
These don’t exist in my screenshot?
Edit: Backup in the admin section worked!! :smiley:
