Isabelle, an Animal Crossing inspired theme
Hey, love this theme, but something is wrong with those elemnts in chat:
CleanShot 2022-11-16 at 20.57.12
How can i fix that or will there be a update ?
The theme was built before chat existed, so it will need an update. I can probably get to that soon.
Oh, great so I also found something else
Hi I am setting up a new Discourse instance, has the Chat been enabled on that lovely theme? Thanks.
Hi! Discourse includes, by default, the chat and should appear in all themes as long it’s enabled!
On mobile, the menu color becomes the same as the background color and is indistinguishable. Can you please fix this issue?
Thanks for reporting it! I’ve just made an update to fix this.
Thanks! And i do not think it is very readable when in dark mode.
Yes, this theme existed before dark mode and hasn’t been updated to support it yet.
Everything else is fine in dark mode, but when I go to my profile/account, it looks blurry because there is not enough contrast.
hi, I have installed this theme, Isabelle. after installation the color palettes set to Isabelle, but still not getting the correct colors on the theme on the entire website. what to do ?
Thanaks
Looks like a dark color palette is being applied (which this theme doesn’t support yet)
Do you have a dark palette set in your site settings? check admin > site settings> Default dark mode color scheme ID
Also check your personal color preferences in community.example.com/my/preferences/interface
Yes. now its okay. thank you for your support. I am very new to this forum.
Thanks again :heart_eyes:
Hi, Chat looks fully transparent after discourse updated. any fix?
Thank you
@awesomerobot
sorry about that! I’ve just made an update that will fix it
hi, here is another UI/UX issue.
Thank you
@awesomerobot
I’ve updated this as well
Awesome theme! There is an issue with text on user cards. I’m using the user card component.
