Problema dopo l'aggiornamento di discourse a una versione stabile
Hi, Today I updated Discourse to a stable version 2.7.7, and after upgrading I received this error while activating a new account
and here is the log tail -----
Failed to handle exception in exception app middleware : PG::UndefinedFunction: ERROR: function max(boolean) does not exist
LINE 1: …_rank, MAX(user_badges.created_at) AS created_at, MAX(user_b…
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
Started GET “/users/activate-account/0f44cb2f759b85caecaf5ea26a1878e5” for 49.44.84.137 at 2021-08-04 11:54:11 +0000
Processing by UsersController#activate_account as HTML
Parameters: {“token”=>“0f44cb2f759b85caecaf5ea26a1878e5”}
Rendered users/activate_account.html.erb within layouts/no_ember (Duration: 2.0ms | Allocations: 471)
Rendered layout layouts/no_ember.html.erb (Duration: 20.5ms | Allocations: 5694)
Completed 200 OK in 29ms (Views: 21.8ms | ActiveRecord: 0.0ms | Allocations: 7981)
can anyone help me with this issue?
How did you upgrade? Do you have any non standard plugins?
I would recommend removing any non standard plugins and doing a rebuild from the command line.
Hi, I upgraded through SSH, the latest version was failing so i upgraded it to the latest stable version (2.7.7).
Here is my app.yml file https://pastebin.com/L1uA68Z5
I guess no non-standard plugin is used.
You went from tests-passed to stable? That won’t work. You need to go back to the default value of version in the app.yml and rebuild.
1 Mi Piace
You’ll need to find out why the upgrade was failing. Changing to stable isn’t going to be a way to resolve that.
Change back to tests-passed, rebuild again, and then report the problem(s).
1 Mi Piace
Okay, I removed the version stable line and rebuilt it again, it failed again and my site is down.
Here is the full error log https://pastebin.com/kdhc563R
Prova a rimuovere GitHub - discourse/discourse-tagging: Tagging functionality for Discourse Forums · GitHub
Il tagging è stato introdotto nel Core nell’aprile del 2016. Se stai utilizzando Discourse 1.6.0.beta2 o una versione successiva, non hai bisogno di questo plugin.
3 Mi Piace
Grazie, ora funziona!
1 Mi Piace
