Issue Rebuilding App Failing on Postgres Upgrade
Trying to do a launcher rebuild and getting this error
I, [2018-06-30T18:56:08.346656 #17]  INFO -- :
I, [2018-06-30T18:56:08.346728 #17]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2018-06-30T18:56:08.357457 #17]  INFO -- :
I, [2018-06-30T18:56:08.357700 #17]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2018-06-30T18:56:08.359892 #17]  INFO -- :
I, [2018-06-30T18:56:08.360109 #17]  INFO -- : > /root/upgrade_postgres
I, [2018-06-30T18:56:08.374537 #17]  INFO -- : Upgrading PostgreSQL from version 9.5 to 10
WARNING: Upgrading PostgresSQL would require an addtional 13M of disk space
Please free up some space, or expand your disk, before continuing.
To avoid upgrading change "templates/postgres.template.yml" TO "templates/postgres.9.5.template.yml" in containers/app.yml
FAILED
Pups::ExecError: /root/upgrade_postgres failed with return #<Process::Status: pid 68 exit 1>
exec failed with the params "/root/upgrade_postgres"
a6266e7beac5a72d92ef181ff8c75b6999b94f5c7831622943c7773a04652c5d
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
It appears to be failing upgrading PostGre because it needs more space? I have plenty of space 23GB
root@EPICORHELP:/var/discourse# df -h
udev            2.0G  4.0K  2.0G   1% /dev
tmpfs           396M  364K  395M   1% /run
/dev/vda1        79G   53G   23G  71% /
none            4.0K     0  4.0K   0% /sys/fs/cgroup
none            5.0M     0  5.0M   0% /run/lock
none            2.0G     0  2.0G   0% /run/shm
none            100M     0  100M   0% /run/user
Any ideas?
Renaming the template as suggested in the error worked… However I don’t understand why its failing. I have plenty of space.
Enter the container and do
df - h
Ok… here’s the output… Looks fine?
root@EPICORHELP:/var/discourse# ./launcher enter app
root@EPICORHELP-app:/var/www/discourse# df -h
none             79G   55G   20G  74% /
tmpfs            64M     0   64M   0% /dev
tmpfs           2.0G     0  2.0G   0% /sys/fs/cgroup
/dev/vda1        79G   55G   20G  74% /shared
shm             512M  4.0K  512M   1% /dev/shm
tmpfs           2.0G     0  2.0G   0% /sys/firmware
You’d need 2x your used space as free space for postgres upgrade to work …
I see 55GB used and 79GB available.
Maybe try upgrade with 170GB storage or more?
2x the database size specifically, to be clear.
Any way to find out the exact database size?
When I take backups within discourse the file generated is 3GB…
With compression, so at least 10gb uncompressed.
du - h /var/discourse/shared/standalone/postgres_data
(from memory and on my phone, so, no promises)
Same problem here:
Run: ./launcher rebuild app
FAILED
Pups::ExecError: /root/upgrade_postgres failed with return #<Process::Status: pid 66 exit 1>
ba104fb4aff36d211ccb42e81365851f64e38219f0d00a336051643fd4255740
And my DB is ~330mb
# du -h /var/discourse/shared/standalone/postgres_data
329M    /var/discourse/shared/standalone/postgres_data
Free space is 26GiB
# df -H
/dev/vda         50G   22G   26G  46% /
@Ignacio_Carrera Did you ever figure this out? I have the same problem
I have a same problem as well :frowning:
Did you see PostgreSQL 12 update?
