Recent rebuilds with Cloudflare support enabled through the official template result in an erroneous line appearing in /etc/nginx/conf.d/discourse.conf:
The result is that the Discourse instance becomes unavailable, with the production.log flooded by:
invalid number of arguments in "set_real_ip_from" directive in /etc/nginx/conf.d/discourse.conf
Commenting out the line immediately resolves the issue.
Has the source data at Cloudflare changed? At the minimum it looks like they might be sending a blank row that will need trimming to avoid recurrences of this issue.
Do you have any way of telling how many installs use Cloudflare @codinghorror? Unless Cloudflare correct their data this issue is likely to impact every install which uses the template. I’d hate for others to experience the same outage and impact as we have today.
I’ve pushed an update which will fix the reported problem. A git pull should get it and a ./launcher rebuild thereafter should produce a working config.
