Issue with Docker on Digital Ocean plan. Would you like to attempt to recover space by cleaning docker images and containers in the system?(y/N)y docker: 'system' is not a docker command
Hi. Im trying to rebuild my app and get the following error:’
root@discourse-2gb-nyc3-01:/var/discourse# ./launcher rebuild app
Fetching origin
remote: Counting objects: 77, done.
remote: Compressing objects: 100% (8/8), done.
remote: Total 77 (delta 50), reused 56 (delta 49), pack-reused 20
Unpacking objects: 100% (77/77), done.
From https://github.com/discourse/discourse_docker
378d927..42504d3 master -> origin/master
+ f38ec69...583394d check-free-space -> origin/check-free-space (forced update)
* [new branch] fix-hsts -> origin/fix-hsts
* [new branch] revert-358-no-env-in-bootstrapped-image -> origin/revert-358-no-env-in-bootstrapped-image
Updating Launcher
Updating 378d927..42504d3
Fast-forward
image/auto_build.rb | 7 ++++---
image/base/Dockerfile | 9 +++++++--
image/base/install-imagemagick | 2 +-
image/base/install-pngquant | 7 ++-----
image/discourse_test/Dockerfile | 3 ++-
launcher | 16 ++++++++++++++++
samples/mail-receiver.yml | 2 +-
templates/web.letsencrypt.ssl.template.yml | 2 +-
templates/web.ssl.template.yml | 6 ++++++
9 files changed, 40 insertions(+), 14 deletions(-)
flag provided but not defined: --format
See '/usr/bin/docker info --help'.
You have less than 5GB of free space on the disk. You will need more space to continue
docker: 'system' is not a docker command.
See 'docker --help'.
If the cleanup was successful, you may try again now
I contacted digital ocean who told me to run this command to see which are the large files on the account.
sudo find / -xdev -type f -size +100M
This gave me this output but I have no clue what anything is and digital ocean says they dont know either and to ask somewhere else.
root@discourse-2gb-nyc3-01:~# sudo find / -xdev -type f -size +100M
/var/lib/docker/aufs/diff/780a8273c9c35d1578ad2e9c37740643ffcc5f9a0a02ed13bd6ad3 6b1d30337e/var/www/discourse/.git/objects/pack/pack-786c3e3931ecb9c41964039462a2 ac21ab04f903.pack
/var/lib/docker/aufs/diff/62de8bb092bdbcfa1c2e276e651597f75b50e9be9fe840a49a8887 5f92d49a4e/var/www/discourse/.git/objects/pack/pack-ad1b9e467013bbde4c943b686ed0 f752aa11e241.pack
/var/lib/docker/aufs/diff/dcdadb45247a230b98d2cbf2f3919ba115c9c5be7dcbb2293b3197 94e9b898c6/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/906c19aa33de1990eae5c0ddcc8f184bffc18e2e26e3a81eb49c0e 37093d3fd0/var/www/discourse/.git/objects/pack/pack-1453eeeb2c0970e6769a7119d737 ec109d8f65cc.pack
/var/lib/docker/aufs/diff/4da38e43cac022d21a8193d829feaa5a46b41209aef340457376d3 03cf962a41/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/75408591168a8d1c7a0dd320dc6ef93ee292d139cba2a62bc5a66e e39de424cd/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/54bd77881e9857e50409c7f962f17f31207d2ced252739efb7ef17 44606850f0/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/fb7cfba393923d5768ec852510705c213877668d90cfa850dd697c d860ae4a32/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/57d799d4c06bbe4e44278bbf1b371037f4fe16047fc7e56c6f414e e0c177ece8/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/ad60b1035f646e9a125f0872ec6d96c7a57a3e104bd8eaa9201545 4c26553691/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/4482660ffadd10299985867a04e84fcdc019b8ef6e9b227f349e4e 000ed67841/var/www/discourse/.git/objects/pack/pack-1453eeeb2c0970e6769a7119d737 ec109d8f65cc.pack
/var/lib/docker/aufs/diff/a75cd7f5028f5c7bd862ed87430136d185fa4d289d902433e93bda beed6a7e54/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/d2c00d454df1d07656601d711d82471f5e5e55db10299d60dad6ba 751f468fab/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/ff74c46bd207d5715d1647c80ebf7233d4fbc8ea54d81b25d43eb8 d85de6de77/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/d2baf46996b2c0aa41294c6c6908c76e4edbecf438b1078976557d 18d18f2577/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/110963d247e29eb5a9ee8118490203d6eaea66cdee92e88b1f04ce 87d691bb16/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/6a2c56759c30fed3a6063c40520625894a2ebc2fe535eaadbe419d 966b091c14/var/www/discourse/.git/objects/pack/pack-ad1b9e467013bbde4c943b686ed0 f752aa11e241.pack
/var/lib/docker/aufs/diff/96307463bdcd7e7af65ae5ac730ba79888155fc41c6bf7d7029ab7 d53ca311c2/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/56ae0770f9955c51d01677c35f4a6f9e61f417dce2ba553b20f355 e63b2ee48b/var/www/discourse/.git/objects/pack/pack-1453eeeb2c0970e6769a7119d737 ec109d8f65cc.pack
/var/lib/docker/aufs/diff/150185fc8bdf50199dd159d9a3cee8c21fd14ef64878325f7ec486 f07ef89234/var/www/discourse/.git/objects/pack/pack-1453eeeb2c0970e6769a7119d737 ec109d8f65cc.pack
/var/lib/docker/aufs/diff/9c706298412117f289d50fac1f82afd7303e81c610bbbaeb64d921 080300d481/var/www/discourse/.git/objects/pack/pack-1453eeeb2c0970e6769a7119d737 ec109d8f65cc.pack
/var/lib/docker/aufs/diff/85f1f1d75570be4c2dca04507ad477a9784e26a7c26ecc0f506b48 5976565491/var/www/discourse/.git/objects/pack/pack-1453eeeb2c0970e6769a7119d737 ec109d8f65cc.pack
/var/lib/docker/aufs/diff/630f9ed1999332022afeceb41c3dc21d811bf6f09888fec5cedbe1 e652c817a6/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd0 12f1a8290078.pack
/var/lib/docker/aufs/diff/bd17a418c6c37e527b2f48469b0e274d2a633a78d388ced04f79e5d28b97a6f6/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd012f1a8290078.pack
/var/lib/docker/aufs/diff/190bad8da2f168ae9ca604f21374dbd9e182998635cce33e1464e065f1c561ce/var/www/discourse/.git/objects/pack/pack-1453eeeb2c0970e6769a7119d737ec109d8f65cc.pack
/var/lib/docker/aufs/diff/4257a4c8045a218a00b60a0d76398f28e122612f08289de805e08c8d903ff213/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd012f1a8290078.pack
/var/lib/docker/aufs/diff/3c2b2dffcfa267c0e6bcc5d7016b68efff7a5f0a017c51213a748d5b40d0feb8/var/www/discourse/.git/objects/pack/pack-1453eeeb2c0970e6769a7119d737ec109d8f65cc.pack
/var/lib/docker/aufs/diff/c6e55b7b8bd3b3cab54010998dd910ef6937fb5686d2f220ea7a7a3cd1c4891f/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd012f1a8290078.pack
/var/lib/docker/aufs/diff/6ea0c94616f38471a0f63b06612602578755a0c04e8f8dbb718d667cc3d86145/var/www/discourse/.git/objects/pack/pack-1453eeeb2c0970e6769a7119d737ec109d8f65cc.pack
/var/lib/docker/aufs/diff/e9ff26f9c95a36d651e2df7e4a164600fc3d0a04e8c4bfcc08c152ecb4750202/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd012f1a8290078.pack
/var/lib/docker/aufs/diff/89111fc5418ab72ed66b461df7eb94189ea40647965596c5fed731330148a969/var/www/discourse/.git/objects/pack/pack-786c3e3931ecb9c41964039462a2ac21ab04f903.pack
/var/lib/docker/aufs/diff/d378f4ccb08d23c4158ea6c47528012345d35f6836bf6e4c7c95a10aec829841/var/www/discourse/.git/objects/pack/pack-1453eeeb2c0970e6769a7119d737ec109d8f65cc.pack
/var/lib/docker/aufs/diff/dd08347f5848c56ddbc80d93755f7d8d204a667084a20e05ba3a3a0cec217529/var/www/discourse/.git/objects/pack/pack-786c3e3931ecb9c41964039462a2ac21ab04f903.pack
/var/lib/docker/aufs/diff/6abd1eebed66038a8ff39533384ac2516a4b1da10fa83bfdc020df76a72ef7ce/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd012f1a8290078.pack
/var/lib/docker/aufs/diff/3202dfb7802efe4dceeeb6b8e89c311fa4b5de718f3ee4c0bae937b9e1d4b2a6/var/www/discourse/.git/objects/pack/pack-d7a718badb9f114ee853b887fdd012f1a8290078.pack
/var/log/btmp
/var/log/btmp.1
I have the
2 GB / 40 GB Disk / NYC3 - Ubuntu Discourse on 14.04
plan on digitial ocean. My site is not the large from what I believe and Im not familiar with docker at all. Can anyone please tell me what the issues are and how to go about correcting this? Im on 1.9.0 beta 1 and getting the notice to upgrade but cant do anything. Thank you.
type docker info please
I was getting the same error. The problem is fixed now. Pls visit the following topic.
Thank you that worked for me.
