Issue with Docker Upgrade from Admin Interface. app not starting
Hi Guys!
Hope you all are doing good. Recently I saw a new update in my discourse admin interface. I just clicked Upgrade button. And then left it. Didn’t look back whether it’s properly installed. Noticed after a day that the site was not working.
I came here searching for the issue. My initial basic try are
I tried
./launcher start app,
Getting the error Cannot connect to the docker daemon - verify it is running and you have access
So
sudo service docker start
to restart docker. it goes normally.
Any other commands I should try?
Using Micro instance and this is almost year old discourse installation.
Try
sudo ./launcher rebuild app
The solution shared on other thread by @pfaffman is the size of the instance.
  • After increasing the size
  • sudo ./launcher rebuild app
So it’s done. and solved. Thanks @pfaffman
