Problème lors de la reconstruction
Je tente de reconstruire et j’obtiens l’erreur suivante concernant postgres :
 FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one.
6d9dad720d559f382809cae944aa4f1aa0eae9b80a09d6c6806b51774680b416
root@discourse:/var/discourse# ./launcher enter app
WARNING: Docker version 24.0.2 deprecated, recommend upgrade to 24.0.7 or newer.
x86_64 arch detected.
Error response from daemon: Container 5618364d766e93a3ea47797a41a8ca500db8c422de8bb5dd6e918d960067698b is not running
root@discourse:/var/discourse# ./launcher start app
starting up existing container
+ /usr/bin/docker start app
app
root@discourse-app:/var/www/discourse# ls -la /etc/postgresql/
total 16
drwxr-xr-x 1 postgres postgres 4096 Mar 13  2026 .
drwxr-xr-x 1 root     root     4096 Mar 13  2026 ..
drwxr-xr-x 3 postgres postgres 4096 Mar 13  2026 13
root@discourse-app:/var/www/discourse# find /etc/postgresql -name postgresql.conf
/etc/postgresql/13/main/postgresql.conf
root@discourse-app:/var/www/discourse# psql --version
psql (PostgreSQL) 13.23 (Debian 13.23-1.pgdg12+1)
root@discourse-app:/var/www/discourse# find /etc/postgresql -type f -name "postgresql.conf" -print
root@discourse-app:/var/www/discourse# grep -R "postgresql/13/main/postgresql.conf" /var/discourse/containers/
grep: /var/discourse/containers/: No such file or directory
root@discourse-app:/var/www/discourse# exit
logout
root@discourse:/var/discourse# grep -R "postgresql/13/main/postgresql.conf" /var/discourse/containers/
root@discourse:/var/discourse# nano containers/app.yml
root@discourse:/var/discourse# ./launcher rebuild app
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20260915-0028: Pulling from discourse/base
Digest: sha256:5028d077b061225507e7093fda1ff5bdc64d483b5c0397776f9a52c50008cd9b
Status: Image is up to date for discourse/base:2.0.20260915-0028
docker.io/discourse/base:2.0.20260915-0028
/usr/local/lib/ruby/gems/3.4.0/gems/pups-1.4.0/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2026-09-15T19:26:20.003232 #1]  INFO -- : Reading from stdin
I, [2026-09-15T19:26:20.014645 #1]  INFO -- : > DEBIAN_FRONTEND=noninteractive apt-get purge -y postgresql-15 postgresql-client-15 postgresql-contrib-15 postgresql-15-pgvector
Reading package lists...
Building dependency tree...
Reading state information...
Package 'postgresql-15' is not installed, so not removed
Package 'postgresql-15-pgvector' is not installed, so not removed
The following packages will be REMOVED:
  postgresql-client-15*
0 upgraded, 0 newly installed, 1 to remove and 7 not upgraded.
After this operation, 8,577 kB disk space will be freed.
(Reading database ... 37993 files and directories currently installed.)
Removing postgresql-client-15 (15.19-1.pgdg13+2) ...
Processing triggers for postgresql-common (293.pgdg13+1) ...
Building PostgreSQL dictionaries from installed myspell/hunspell packages...
Removing obsolete dictionary files:
I, [2026-09-15T19:26:23.405525 #1]  INFO -- : > apt-get update && apt-get install -y postgresql-13 postgresql-client-13 postgresql-contrib-13 postgresql-13-pgvector
Hit:1 http://deb.debian.org/debian trixie InRelease
Get:2 http://deb.debian.org/debian trixie-updates InRelease [47.3 kB]
Get:3 http://deb.debian.org/debian trixie-security InRelease [43.4 kB]
Get:4 http://deb.debian.org/debian trixie-backports InRelease [54.0 kB]
Hit:5 https://apt.postgresql.org/pub/repos/apt trixie-pgdg InRelease
Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
Get:7 http://deb.debian.org/debian trixie-backports/main amd64 Packages.diff/Index [63.3 kB]
Get:8 http://deb.debian.org/debian trixie-backports/main amd64 Packages T-2026-09-15-0200.42-F-2026-09-15-0200.42.pdiff [715 B]
Fetched 209 kB in 0s (514 kB/s)
Suggested packages:
  postgresql-doc-13
The following NEW packages will be installed:
  postgresql-13 postgresql-13-pgvector postgresql-client-13
0 upgraded, 3 newly installed, 0 to remove and 7 not upgraded.
Need to get 15.8 MB of archives.
After this operation, 55.0 MB of additional disk space will be used.
Get:1 https://apt.postgresql.org/pub/repos/apt trixie-pgdg/main amd64 postgresql-client-13 amd64 13.23-2.pgdg13+2 [1,560 kB]
Get:2 https://apt.postgresql.org/pub/repos/apt trixie-pgdg/main amd64 postgresql-13 amd64 13.23-2.pgdg13+2 [13.9 MB]
Get:3 https://apt.postgresql.org/pub/repos/apt trixie-pgdg/main amd64 postgresql-13-pgvector amd64 0.8.6-1.pgdg13+1 [271 kB]
debconf: unable to initialize frontend: Teletype
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Noninteractive
Preconfiguring packages ...
Fetched 15.8 MB in 0s (32.1 MB/s)
Selecting previously unselected package postgresql-client-13.
(Reading database ... 37639 files and directories currently installed.)
Preparing to unpack .../postgresql-client-13_13.23-2.pgdg13+2_amd64.deb ...
Unpacking postgresql-client-13 (13.23-2.pgdg13+2) ...
Selecting previously unselected package postgresql-13.
Preparing to unpack .../postgresql-13_13.23-2.pgdg13+2_amd64.deb ...
Unpacking postgresql-13 (13.23-2.pgdg13+2) ...
Selecting previously unselected package postgresql-13-pgvector.
Preparing to unpack .../postgresql-13-pgvector_0.8.6-1.pgdg13+1_amd64.deb ...
Unpacking postgresql-13-pgvector (0.8.6-1.pgdg13+1) ...
Setting up postgresql-client-13 (13.23-2.pgdg13+2) ...
Setting up postgresql-13 (13.23-2.pgdg13+2) ...
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of start.
Setting up postgresql-13-pgvector (0.8.6-1.pgdg13+1) ...
I, [2026-09-15T19:26:33.924838 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2026-09-15T19:26:33.937383 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2026-09-15T19:26:33.948008 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2026-09-15T19:26:33.957031 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
FAILED
Errno::ENOENT: No such file or directory @ rb_sysopen - /etc/postgresql/13/main/postgresql.conf
Location of failure: /usr/local/lib/ruby/gems/3.4.0/gems/pups-1.4.0/lib/pups/replace_command.rb:11:in 'IO.read'
replace failed with the params {"filename" => "/etc/postgresql/13/main/postgresql.conf", "from" => "data_directory = '/var/lib/postgresql/13/main'", "to" => "data_directory = '/shared/postgres_data'"}
e872bf2ce6397fc303a1082dd69a2a821ebe167797a51f12c7895f00d95efd31
root@discourse:/var/discourse# ./launcher help
Usage: launcher COMMAND CONFIG [--skip-prereqs] [--docker-args STRING]
Commands:
    start:       Start/initialize a container
    stop:        Stop a running container
    restart:     Restart a container
    destroy:     Stop and remove a container
    enter:       Open a shell to run commands inside the container
    logs:        View the Docker logs for a container
    bootstrap:   Bootstrap a container for the config based on a template
    run:         Run the given command with the config in the context of the last bootstrapped image
    rebuild:     Rebuild a container (destroy old, bootstrap, start new)
    cleanup:     Remove all containers that have stopped for > 24 hours
    start-cmd:   Generate docker command used to start container
Options:
    --skip-prereqs             Don't check launcher prerequisites
    --docker-args              Extra arguments to pass when running docker
    --skip-mac-address         Don't assign a mac address
    --run-image                Override the image used for running the container
root@discourse:/var/discourse# git pull
Already up to date.
root@discourse:/var/discourse# git status
On branch main
Your branch is up to date with 'origin/main'.
nothing to commit, working tree clean
root@discourse:/var/discourse# git pull origin main
From https://github.com/discourse/discourse_docker
 * branch            main       -> FETCH_HEAD
Already up to date.
Fetching origin
app
I, [2026-09-15T19:30:33.425701 #1]  INFO -- : Reading from stdin
I, [2026-09-15T19:30:33.433210 #1]  INFO -- : > DEBIAN_FRONTEND=noninteractive apt-get purge -y postgresql-15 postgresql-client-15 postgresql-contrib-15 postgresql-15-pgvector
I, [2026-09-15T19:30:36.871090 #1]  INFO -- : > apt-get update && apt-get install -y postgresql-13 postgresql-client-13 postgresql-contrib-13 postgresql-13-pgvector
Get:6 http://deb.debian.org/debian trixie-backports/main amd64 Packages.diff/Index [63.3 kB]
Get:7 http://deb.debian.org/debian trixie-backports/main amd64 Packages T-2026-09-15-0200.42-F-2026-09-15-0200.42.pdiff [715 B]
Hit:8 https://deb.nodesource.com/node_22.x nodistro InRelease
Fetched 209 kB in 0s (456 kB/s)
Suggested packages:
  postgresql-doc-13
Fetched 15.8 MB in 1s (27.9 MB/s)
I, [2026-09-15T19:30:47.866832 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2026-09-15T19:30:47.873732 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2026-09-15T19:30:47.883656 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2026-09-15T19:30:47.894944 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
FAILED
f2487d88dbf2688af4d2f9efe5031277f9becd3e8deaaee59936b5a3282825cb
launcapp
root@discourse-app:/var/www/discourse# find /etc/postgresql -maxdepth 4 -type f -name "postgresql.conf" -print
root@discourse-app:/var/www/discourse# ls -l /etc/postgresql/13/main/postgresql.conf
-rw-r--r-- 1 postgres postgres 28160 Mar 13  2026 /etc/postgresql/13/main/postgresql.conf
root@discourse-app:/var/www/discourse# grep "data_directory" /etc/postgresql/13/main/postgresql.conf
data_directory = '/shared/postgres_data'                # use data in another directory
root@discourse-app:/var/www/discourse# grep -n "data_directory" /etc/postgresql/13/main/postgresql.conf
42:data_directory = '/shared/postgres_data'             # use data in another directory
root@discourse-app:/var/www/discourse# cat /shared/postgres_data/PG_VERSION
13
root@discourse-app:/var/www/discourse# pg_isready
/var/run/postgresql:5432 - accepting connections
root@discourse-app:/var/www/discourse# grep -R -n "postgresql/13/main/postgresql.conf" containers/
grep: containers/: No such file or directory
logout
root@discourse:/var/discourse# grep -R -n "postgresql/13/main/postgresql.conf" containers/
root@discourse:/var/discourse# grep -R -n "data_directory = '/var/lib/postgresql/13/main'" .
./templates/postgres.13.template.yml:78:      from: "data_directory = '/var/lib/postgresql/13/main'"
root@discourse:/var/discourse# sed -n '60,90p' templates/postgres.13.template.yml
        rm -fr /var/run/postgresql
        ln -s /shared/postgres_run /var/run/postgresql
        if [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
          socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
        fi
        rm -fr /shared/postgres_run/.s*
        rm -fr /shared/postgres_run/*.pid
        mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
        chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
        chown -R root /var/lib/postgresql/13/main
        [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
        chown -R postgres:postgres /shared/postgres_data
        chown -R postgres:postgres /var/run/postgresql
        # Necessary to enable backups
        install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
  - replace:
      filename: "/etc/postgresql/13/main/postgresql.conf"
      to: "data_directory = '/shared/postgres_data'"
  # listen on all interfaces
  - replace:
      to: "listen_addresses = '*'"
  # sync commit off is faster and less spiky, also marginally less safe
  - replace:
Fetching origin
app
I, [2026-09-15T19:36:55.987481 #1]  INFO -- : Reading from stdin
I, [2026-09-15T19:36:55.994696 #1]  INFO -- : > DEBIAN_FRONTEND=noninteractive apt-get purge -y postgresql-15 postgresql-client-15 postgresql-contrib-15 postgresql-15-pgvector
I, [2026-09-15T19:36:59.425952 #1]  INFO -- : > apt-get update && apt-get install -y postgresql-13 postgresql-client-13 postgresql-contrib-13 postgresql-13-pgvector
Fetched 209 kB in 0s (597 kB/s)
Suggested packages:
  postgresql-doc-13
Fetched 15.8 MB in 1s (28.3 MB/s)
I, [2026-09-15T19:37:10.443093 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2026-09-15T19:37:10.451905 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2026-09-15T19:37:10.461850 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2026-09-15T19:37:10.470555 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
FAILED
a03ab568b935075489b4f4b426d39e7484750f0c48be458f5450d17e60d3ee07
avez-vous une sauvegarde récente ?
il semble que vous n’ayez pas effectué de mise à niveau depuis assez longtemps ? (à en juger par les références à Postgres … 13 ! - la mise à niveau vers Postgres 15 a été proposée il y a plus d’un an et demi)
Je vous recommande fortement de migrer vers un nouveau serveur en utilisant votre dernière sauvegarde.
Cela éviterait beaucoup de péripéties liées aux mises à niveau et devrait se faire sans trop de douleur.
Je vous recommande également fortement d’encadrer le journal avec des triples backticks, comme ceci :
log here
