Issue with SSL Certificate
we found that the origin certificate is issued by ISRG Root X1, which is not supported by Akamai. The origin certificate needs to be issued by DigiCert or need to install our 5 paisa SSL certificate on origin.
If you follow the standard install you’ll have a letsencrypt certificate which is supported and automatically renews.
If you want to use a custom certificate, there exists a topic describing how to do it.
