Javascript error if emoji_autocomplete_min_chars setting > 0 for each character typed after a colon in the composer
A Javascript error occurs when the emoji_autocomplete_min_chars site setting is greater than 0, causing a TypeError: e.map is not a function error in the composer. The error happens when typing characters after a colon, and the colon must be the first character of the line or have a space before it. The error appears for the first few characters typed before the emoji selector is shown. Canapin discovered the issue and joffreyjaffeux confirmed the repro and created a fix, which has now been merged (joffreyjaffeux).
Uncaught (in promise) TypeError: e.map is not a function in d.editor
edit : re-writing now that I have found the cause
After some testing, it appears that this error happens when the emoji_autocomplete_min_chars site setting is set to a value different than 0.
The error will occur each time we type a character after a colon. Also, the colon must be the first character of the line or have a space character before.
If emoji_autocomplete_min_chars is set to 3, the error will appear for the first 3 characters typed before the emoji selector is shown.
composer error
I don’t know if it affects anything or causes unwanted behavior that I can’t see behind the curtains.
edit: 2.9.0.beta3 and beta2, tried in safe mode :slight_smile:
Yikes, let us have a debug of this… will have a look over the next week.
@j.jaffeux do you mind having a quick look? :eyes:
Hi,
I will look at writing a test for this after Lunch but just confirming the repro was correct and I have a fix ready soon:
https://github.com/discourse/discourse/pull/16465
:+1:
Merged thanks for report :+1:
This topic was automatically closed 5 days after the last reply. New replies are no longer allowed.
