חריגת עבודה: DistributedMutex::MaximumAttemptsExceeded
Hi,
We keep seeing these error notices in our forum logs. Should we worry about it or/and adjust any settings?
backtrace
/var/www/discourse/lib/distributed_mutex.rb:113:in `get_lock'
/var/www/discourse/lib/distributed_mutex.rb:62:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:61:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:45:in `synchronize'
/var/www/discourse/app/jobs/regular/notify_reviewable.rb:25:in `execute'
/var/www/discourse/app/jobs/base.rb:249:in `block (2 levels) in perform'
rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:80:in `with_connection'
/var/www/discourse/app/jobs/base.rb:236:in `block in perform'
/var/www/discourse/app/jobs/base.rb:232:in `each'
/var/www/discourse/app/jobs/base.rb:232:in `perform'
sidekiq-6.5.8/lib/sidekiq/processor.rb:202:in `execute_job'
sidekiq-6.5.8/lib/sidekiq/processor.rb:170:in `block (2 levels) in process'
sidekiq-6.5.8/lib/sidekiq/middleware/chain.rb:177:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:134:in `call'
sidekiq-6.5.8/lib/sidekiq/middleware/chain.rb:179:in `block in invoke'
sidekiq-6.5.8/lib/sidekiq/middleware/chain.rb:182:in `invoke'
sidekiq-6.5.8/lib/sidekiq/processor.rb:169:in `block in process'
sidekiq-6.5.8/lib/sidekiq/processor.rb:136:in `block (6 levels) in dispatch'
sidekiq-6.5.8/lib/sidekiq/job_retry.rb:113:in `local'
sidekiq-6.5.8/lib/sidekiq/processor.rb:135:in `block (5 levels) in dispatch'
sidekiq-6.5.8/lib/sidekiq.rb:44:in `block in <module:Sidekiq>'
sidekiq-6.5.8/lib/sidekiq/processor.rb:131:in `block (4 levels) in dispatch'
sidekiq-6.5.8/lib/sidekiq/processor.rb:263:in `stats'
sidekiq-6.5.8/lib/sidekiq/processor.rb:126:in `block (3 levels) in dispatch'
sidekiq-6.5.8/lib/sidekiq/job_logger.rb:13:in `call'
sidekiq-6.5.8/lib/sidekiq/processor.rb:125:in `block (2 levels) in dispatch'
sidekiq-6.5.8/lib/sidekiq/job_retry.rb:80:in `global'
sidekiq-6.5.8/lib/sidekiq/processor.rb:124:in `block in dispatch'
sidekiq-6.5.8/lib/sidekiq/job_logger.rb:39:in `prepare'
sidekiq-6.5.8/lib/sidekiq/processor.rb:123:in `dispatch'
sidekiq-6.5.8/lib/sidekiq/processor.rb:168:in `process'
sidekiq-6.5.8/lib/sidekiq/processor.rb:78:in `process_one'
sidekiq-6.5.8/lib/sidekiq/processor.rb:68:in `run'
sidekiq-6.5.8/lib/sidekiq/component.rb:8:in `watchdog'
sidekiq-6.5.8/lib/sidekiq/component.rb:17:in `block in safe_thread'
env
hostname
process_id 189676
application_version 2f8ad17aed81bbfa2fd20b6cc9210be92779bd74
current_db default
current_hostname
job Jobs::NotifyReviewable
problem_db default
time 4:02 pm
opts
reviewable_id 8980
current_site_id default
Are you still seeing this @kinetiksoft? Is it that specific reviewable it’s having an issue with? (/review/8980)
I don’t see this specific error now, yet we have different Job Exception with inappropriate amount of repeats which states:
Job exception: uninitialized constant Jobs::ClassifyChatMessage::ChatMessage
Backtrace
/var/www/discourse/plugins/disorder/app/jobs/regular/classify_chat_message.rb:11:in execute' /var/www/discourse/app/jobs/base.rb:249:in block (2 levels) in perform’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:80:in with_connection' /var/www/discourse/app/jobs/base.rb:236:in block in perform’
/var/www/discourse/app/jobs/base.rb:232:in each' /var/www/discourse/app/jobs/base.rb:232:in perform’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.8/lib/sidekiq/processor.rb:202:in execute_job' /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.8/lib/sidekiq/processor.rb:170:in block (2 levels) in process’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.8/lib/sidekiq/middleware/chain.rb:177:in block in invoke' /var/www/discourse/lib/sidekiq/pausable.rb:134:in call’
Additional details
Column 1 Column 2
hostname {redacted}
process_id 1657082
application_version c1c017f4333ad1aaec509c39bdc313420ea4e5a7
current_db default
current_hostname {redacted}
job Jobs::ClassifyChatMessage
problem_db default
time 1:06 pm
opts
chat_message_id 2444
May I kindly hijack your attention while you’re here in regards to other bug which is described here:
https://meta.discourse.org/t/discourse-gifs/158738/235?u=kinetiksoft
Just in case there will be luck into getting someone’s attention within internal Discourse team chats…
At least that’s good news. :slight_smile: :partying_face:
I’m not sure about this second error. It looks like it’s the AI classification module having an issue with a chat message? It’s a little vague, but does that help at all?
I spotted you posted a follow-up in the GIFS topic Discourse Gifs - #243 by Muhammed_EKİCİ Hopefully that should get it some attention. :crossed_fingers:
