L’importation de données via json_generic.rb échoue actuellement avec :
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activemodel-6.1.3.2/lib/active_model/attribute_methods.rb:469:in `method_missing': méthode undefined `token=' pour #<EmailToken:0x00005645c4df6618> (NoMethodError)
Vous vouliez dire ? token_hash
Cela fonctionnait auparavant en juin 2021 — le problème pourrait-il être lié à ce commit ?
Voici la trace d’appel complète :
Traceback (most recent call last):
84: from script/import_scripts/json_generic.rb:108:in `<main>'
83: from /var/www/discourse/script/import_scripts/base.rb:47:in `perform'
82: from script/import_scripts/json_generic.rb:22:in `execute'
81: from script/import_scripts/json_generic.rb:53:in `import_users'
80: from /var/www/discourse/script/import_scripts/base.rb:264:in `create_users'
79: from /var/www/discourse/script/import_scripts/base.rb:264:in `each'
78: from /var/www/discourse/script/import_scripts/base.rb:276:in `block in create_users'
77: from /var/www/discourse/script/import_scripts/base.rb:344:in `create_user'
76: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/transactions.rb:209:in `transaction'
75: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `transaction'
74: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/connection_adapters/abstract/transaction.rb:308:in `within_new_transaction'
73: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
72: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
71: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
70: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
69: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
68: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/connection_adapters/abstract/transaction.rb:310:in `block in within_new_transaction'
67: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `block in transaction'
66: from /var/www/discourse/script/import_scripts/base.rb:345:in `block in create_user'
65: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/suppressor.rb:48:in `save!'
64: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/transactions.rb:302:in `save!'
63: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/transactions.rb:350:in `with_transaction_returning_status'
62: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/connection_adapters/abstract/database_statements.rb:318:in `transaction'
61: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/transactions.rb:354:in `block in with_transaction_returning_status'
60: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/transactions.rb:302:in `block in save!'
59: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/validations.rb:53:in `save!'
58: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/persistence.rb:507:in `save!'
57: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/timestamp.rb:126:in `create_or_update'
56: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/callbacks.rb:457:in `create_or_update'
55: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:824:in `_run_save_callbacks'
54: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:137:in `run_callbacks'
53: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:126:in `block in run_callbacks'
52: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/autosave_association.rb:385:in `around_save_collection_association'
51: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
50: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/callbacks.rb:457:in `block in create_or_update'
49: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/persistence.rb:900:in `create_or_update'
48: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/timestamp.rb:108:in `_create_record'
47: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/callbacks.rb:461:in `_create_record'
46: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:824:in `_run_create_callbacks'
45: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:107:in `run_callbacks'
44: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:516:in `invoke_after'
43: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:516:in `each'
42: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:516:in `block in invoke_after'
41: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:235:in `block in halting_and_conditional'
40: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:427:in `block in make_lambda'
39: from /var/www/discourse/app/models/user.rb:1460:in `create_email_token'
38: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/collection_proxy.rb:364:in `create!'
37: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/association.rb:209:in `create!'
36: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/has_many_association.rb:137:in `_create_record'
35: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/collection_association.rb:357:in `_create_record'
34: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/collection_association.rb:134:in `transaction'
33: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/transactions.rb:209:in `transaction'
32: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/connection_adapters/abstract/database_statements.rb:318:in `transaction'
31: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/collection_association.rb:135:in `block in transaction'
30: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/collection_association.rb:359:in `block in _create_record'
29: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/collection_association.rb:285:in `add_to_target'
28: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/collection_association.rb:460:in `replace_on_target'
27: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/collection_association.rb:360:in `block (2 levels) in _create_record'
26: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/has_many_association.rb:58:in `insert_record'
25: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/associations/collection_association.rb:373:in `insert_record'
24: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/suppressor.rb:48:in `save!'
23: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/transactions.rb:302:in `save!'
22: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/transactions.rb:350:in `with_transaction_returning_status'
21: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/connection_adapters/abstract/database_statements.rb:318:in `transaction'
20: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/transactions.rb:354:in `block in with_transaction_returning_status'
19: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/transactions.rb:302:in `block in save!'
18: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/validations.rb:53:in `save!'
17: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/validations.rb:84:in `perform_validations'
16: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/validations.rb:68:in `valid?'
15: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activemodel-6.1.3.2/lib/active_model/validations.rb:337:in `valid?'
14: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activemodel-6.1.3.2/lib/active_model/validations/callbacks.rb:117:in `run_validations!'
13: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:824:in `_run_validation_callbacks'
12: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:105:in `run_callbacks'
11: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:512:in `invoke_before'
10: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:512:in `each'
9: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:512:in `block in invoke_before'
8: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:180:in `block in halting_and_conditional'
7: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:603:in `block in default_terminator'
6: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:603:in `catch'
5: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:604:in `block (2 levels) in default_terminator'
4: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:179:in `block (2 levels) in halting_and_conditional'
3: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:427:in `block in make_lambda'
2: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/callbacks.rb:427:in `instance_exec'
1: from /var/www/discourse/app/models/email_token.rb:9:in `block in <class:EmailToken>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activemodel-6.1.3.2/lib/active_model/attribute_methods.rb:469:in `method_missing': méthode undefined `token=' pour #<EmailToken:0x000055fb6b4965f8> (NoMethodError)
Quelqu’un d’autre rencontre-t-il ce problème ? Ou manque-t-il quelque chose de mon côté ?
