Gedood bij bundle exec rake themes:update assets:precompile
 [2024-02-05T07:05:17.407418 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
111:M 05 Feb 2024 07:05:31.061 * 100 changes in 300 seconds. Saving...
111:M 05 Feb 2024 07:05:31.063 * Background saving started by pid 3496
3496:C 05 Feb 2024 07:05:31.222 * DB saved on disk
3496:C 05 Feb 2024 07:05:31.223 * Fork CoW for RDB: current 1 MB, peak 1 MB, average 1 MB
111:M 05 Feb 2024 07:05:31.263 * Background saving terminated with success
I, [2024-02-05T07:05:32.565285 #1]  INFO -- : gem install ruby-openid -v 2.9.2 -i /var/www/discourse/plugins/discourse-steam-login/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed ruby-openid-2.9.2
1 gem installed
gem install rack-openid -v 1.3.1 -i /var/www/discourse/plugins/discourse-steam-login/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed rack-openid-1.3.1
1 gem installed
gem install omniauth-openid -v 1.0.1 -i /var/www/discourse/plugins/discourse-steam-login/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed omniauth-openid-1.0.1
1 gem installed
gem install omniauth-steam -v 1.0.6 -i /var/www/discourse/plugins/discourse-steam-login/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed omniauth-steam-1.0.6
1 gem installed
I, [2024-02-05T07:05:32.565781 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
Killed
error Command failed with exit code 137.
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3497 exit 137>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
bootstrap failed with exit code 137
1901476353b23c1963cfaecc063b5cbf4c367bb3dce9b95c5bdb39faa7474682
==================== END REBUILD LOG ====================
Failed to rebuild app.
my app.yml:
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  ## Uncomment the next line to enable the IPv6 listener
  #- "templates/web.ipv6.template.yml"
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "8880:80"   # http
  - "4443:443" # https
params:
  db_shared_buffers: "1024MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  NODE_OPTIONS: "--max-old-space-size=2048"
  UNICORN_WORKERS: 4
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: 'www.palworld.hk'
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'paojiao@palworld.hk'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: smtp.exmail.qq.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: noreply@palworld.hk
  DISCOURSE_SMTP_PASSWORD: BV6n8BBhpDaZ5DZQ
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  #DISCOURSE_SMTP_DOMAIN: discourse.example.com    # (required by some providers)
  DISCOURSE_NOTIFICATION_EMAIL: noreply@palworld.hk    # (address to send notifications from)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP address key for IP address lookup
  ## see https://meta.discourse.org/t/-/137387/23 for details
  DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-steam-login.git
          - git clone https://github.com/discourse/discourse-gamification.git
          - git clone https://github.com/whitewatercn/discourse-embed-bilibili.git
          - git clone https://github.com/communiteq/discourse-private-topics.git
          - git clone https://github.com/discourse/discourse-signup-banner.git
          - git clone https://github.com/discourse/discourse-adplugin.git
          - git clone https://github.com/discourse/discourse-whos-online.git
          - git clone https://github.com/discourse/discourse-topic-voting.git
          - git clone https://github.com/paviliondev/discourse-tickets.git
run:
I tried
egrep -i 'killed process' /var/log/messages
but there was no response
This is an ‘out of memory’ error. There have been a few topics about this recently. You may need to upgrade your specs, though there are also a couple of things you could try before making a permanent change:
emm But My server configuration is 4C4G
How much swap do you have?
Latest progress: After deleting a previously installed theme [Graceful], I successfully rebuild it
Just as an FYI in case deleting that theme wasn’t a crucial factor, there have been reports of encountering the error 137 intermittently. So sometimes it’ll fail a couple of times and then another time could be successful even though no changes were made.
But if you hit it again at least you’ll have an idea of what can be done. :+1:
