The Knowledge Base theme component enables a knowledge base style view for selected categories. It adds a KB button to the navigation bar, allowing users to toggle between the regular category view and the knowledge base view. The knowledge base view displays a stripped-down version of the latest topic list, with the ability to filter by tags.
The theme component requires the tagging_enabled and show_filter_by_tag site settings to be enabled. It also has some limitations, such as not working with the Knowledge Base Plugin and having conflicts with certain other theme components.
Users have reported several issues with the theme component, including:
The KB button not working as expected
The tags menu not appearing in the sidebar
The category view not defaulting to the KB view
Conflicts with other theme components, such as the Popular Tags theme component
Issues with subcategories and tag groups
The author of the theme component, Justin, has been actively responding to user feedback and fixing issues. However, due to changes in the Discourse category routing, the theme component is currently broken for versions 2.4 and later. The author recommends using the Knowledge Explorer Plugin instead.
Justin has also mentioned that a more advanced version of the theme component is in the works, which will be released as a plugin. This plugin will have more features and will be more robust than the current theme component.
Click a tag in the sidebar and the topic list automatically filters by that tag. You can select as many tags as you want, and the tag list will show only tags added to the filtered topics for ease of browsing lots of documentation.
We’ve been using Discourse as our KB for 4+ years and have around 350 Knowledge Base specific posts, so this very exciting!
I’m not sure if this is possible via a theme component, but is there anyway this “view” could be the default when someone opens a category? So that rather than going to: /c/knowledge-base that it would automatically load as /c/knowledge-base?kb=active?
We’ve enabled the KB theme component and really like it but we worry that people aren’t seeing the KB view because they’re using the /c/knowledge-base link they’ve previously bookmarked.
Thank you so much for this! We have a category in our community that would be perfect for applying this component, but we are facing an issue: categories don’t show up in the “kb categories” drop down so we can’t choose the category to apply the component. Any advice?
You can just type in the category slug and create it. It is not extremely intuitive. I have not been able to figure out how to get sub categories but if your category is on the first level it is pretty easy.
No special syntax - just enter the slug of the category (subcategory or not) in the kb categories theme setting, refresh your browser, and it should work.
This is a limitation of theme settings right now – you’ll have to type in the slug as @Sean_R suggested.
Did you get this sorted @TowerBR? Did you refresh after adding the category to the setting? Did you click the KB button? Sorry for the silly questions but trying to get to the bottom of it.
Odd - ok. If you can repro it consistently, let me know and I’ll take a look. I haven’t been able to get that behavior to fire using the subcategory dropdown.
Yep, I had already done that, see the picture of the post above:
I removed the “Custom top navigation links” component. It is now a completely “clean” installation:
Yes, and I cleaned the cache.
Yes. When I select the category by main drop down it already loads the category page with /c/diy?kb=active at the end of the URL. When I hover the KB button, it shows the “normal” URL without this “add-on”, but when I click on it nothing happens.
This is awesome! Just installed it to take a look, and I can see it is already very useful.
This theme component does seem to conflict with https://meta.discourse.org/t/knowledge-base-plugin/115288 by @angus. I can confirm that the plugin has to be uninstalled prior to enabling this theme component, otherwise the below happens when you look at a knowledge base category. Note the weird horizontal line next to the menu and spinning circle.
I’d love to hear some more about the advanced version and what you have planned. Some feedback:
bug? when you select a tag from the left menu to filter by that tag, and then click to another category or latest etc.. then when you next click on kb to return to the knowledge base you will find you are still filtering by that tag.
when you click on the tag under a title, it takes you to the tag page for that tag, not to a filtered kb view as it does when you click the tag on the left menu.
click on the tag category title on the left menu, and you are taken to the latest view for the category. I’d suggest this not link to anywhere. The category title also should probably not have # which is a distraction.
it would be handy to see the number of topics with each tag on the left menu
it would be handy to be able to sort kb topics alphabetically or even in custom order
