Hi. We run a platform with multiple label sets. This means we can customise what each user type is called, specific to each organisation. We need to publish our documentation with variables for our multiple label sets so we do not need to individually reference every user for each custom label set. Any suggestions?
zach-ehealthier seeks advice on documenting a platform with customizable user label sets (e.g., Admin, Acquirer, Practice Principal, Provider, Patient), which vary per organization. Since each organization can define its own labels (e.g., Claims Manager, Claims Advisor, Claimant), static documentation becomes confusing. zach-ehealthier asks if placeholders can dynamically adapt to the logged-in user’s label set. pfaffman responds by suggesting using Discourse groups (excluding “admin” due to its special status, perhaps renaming it “medical admin”) and organizing categories for each group. They recommend using DiscourseConnect SSO to pass group memberships on login, enabling dynamic content or access control based on user roles. They also link to group access configuration for further setup guidance. The core issue revolves around dynamic documentation tied to user-specific label sets, and the proposed solution leverages Discourse’s group and SSO features to achieve role-based content personalization.
Welcome @zach-ehealthier.
I don’t understand what you’re trying to do.
What does this have to do with groups (collections of users) and categories (collections of topics)?
Can you give a specific example of what problem you are solving with your label sets?
Hi @pfaffman
On our platform we have a user hierarchy as follows:
U1 - Admin
U2 - Acquirer
U4 - Practice Principal
U6 - Provider
U7 - Patient
This is our default label set. When an organisation purchases from us they can specify a new label set to be used specifically for their organisation. This can look like:
U1 - Admin
U2 - Acquirer
U4 - Claims Manager
U6 - Claims Advisor
U7 - Claimant
Or any other combination (unlimited possibilities)
When writing our knowledge base documentation we can not only refer to one label set as this will confuse users. Is there a way we can use some sort of placeholder to change that placeholder based on the user that is logged in? Or if you have any other ideas on how to approach this issue?
You can create groups with those names, except admin, which has a special user already. Perhaps you’d call it “medical admin” or similar. Then you’d create create categories for them for their discussions.
See How to set / configure private / closed group access, membership and visibility
Also see Setup DiscourseConnect - Official Single-Sign-On for Discourse (sso) for hints on how to set up sso and pass those group memberships on login.
