Laatste waarschuwing bij het reageren op oude onderwerpen
Hello,
I’m running a community that historically has a bit of a problem with necro-bumping threads.
I am familiar with warn_reviving_old_topic_age (and we do have it set), but it seems that many users aren’t seeing the alert. We also don’t want to institute global topic timers because there really are use cases where reviving the old thread is useful.
Our previous solution was to block posting on an “are you sure” dialog based on this component:
however, both our necro-warning and the linked component above no longer seems to work (an out-of-the-box install of the admin-warnings thread allows me to post in closed topics unimpeded).
How should I proceed? I’m not afraid of getting my hands dirty and building my own component/plugin from the ground, but I’ve been struggling to find documentation on where to start.
is dit niet iets dat via moderatie afgehandeld kan worden? Stuur gewoon een PM met een waarschuwing naar de mensen die de necrobumping doen om hen te laten weten dat ze dat niet moeten doen?
Als het aanhoudt, kun je een aankondigingstopic aanmaken en deze banneren om het beleid te versterken.
I think a little added friction with a confirmation pop-up is perhaps more proportionate than going straight in with a full-on official warning. :slight_smile:
Though if certain members routinely ignore the pop-up you may still need to reach out to find out what their thinking is. They may just need a friendly nudge to realise what’s expected. :crossed_fingers:
I think if you’re looking to build your own theme component for this you may be better slipping this over to the Dev category to get more eyes on it. :eyes:
I haven’t checked to see if the necro warning still shows for me, but generally the Just In Time (JIT) messages don’t show up on mobile (which is unfortunate :frowning:). And it does look like the Warn admins/tl4 when replying to closed topics theme component is marked as broken now.
Dev is not my forte, so I’m afraid I’m not going to be a world of help, but you can find the official guides in Documentation > Developer Guides.
Hopefully David fixes Warn admins/tl4 when replying to closed topics and then you can see what needs changing in your own one. :slight_smile: :crossed_fingers:
Maybe Unformatted Code Detector could work as an example for a new component. That also shows a warning when you try to post.
Bedankt! Ik zal het bekijken en zien wat ik kan doen!
Ik heb dit naar Dev verplaatst, waar het kan blijven terwijl je verdergaat met je component. Laat ons weten hoe het gaat!
Continues in:
