i’m getting a 502 now… only thing that i had done recently is update via web to the latest build.
i’ve tried restarting hard, then doing your typical restart
and rebuild
… no dice.
and rebuild
… no dice.
Try to refresh the page or wait in a moment?
Did the rebuild go through without errors?
Have you updated your OS?
We had a problem yesterday (i.e. a few updates behind you) with the site not being available. A reboot fixed that, and we’ve since updated to the latest per yesterday. Site is fine now.
Hi, i’m getting the same error. How can i remove the plugin?
You need to ssh into your machine, and as root, edit /var/discourse/containers/app.yml
Down near the bottom of the file there is a section where all the plugins are listed. Put a “#” at the beginning of that line, save the file.
Then rebuild:
cd …
./launcher rebuild app
That’s it.
