I upgraded to
today and the theme is all messed up
Is there something wrong that I’ve done?
Disable cloudflare acceleration?
Did that. Moved CloudFlare to development mode and bypass caching. No luck there.
Here’s my developer console.
Edit: the 404 JS file is at /cdn-cgi/apps/head/4gOrM_ieGMocV_slTew8RsUZoVk.js
That js file is not ours, I would try safe mode
Have you tried this too?
And then refresh using the hard mode: Ctrl+Shift+R
Or try Incognito mode
Questo argomento è stato chiuso automaticamente dopo 2407 giorni. Non sono più consentite nuove risposte.
