새로운 Discourse Docker 이미지를 빌드하고 있는데, migrate 단계에서 실패하는 것 같습니다.
I, [2020-12-15T15:02:28.688540 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2020-12-15T15:04:19.530701 #1] INFO -- :
I, [2020-12-15T15:04:19.530966 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
Purging temp files
Bundling assets
I, [2020-12-15T15:04:36.448680 #374] INFO -- : Writing /var/www/discourse/public/assets/vendor-bdb3fefe8aefde7bf6aef331a6edd24482502b370ed9f6f299836c72ee6a843c.js
I, [2020-12-15T15:04:43.818563 #374] INFO -- : Writing /var/www/discourse/public/assets/admin-073db5e5695d9f3834b9ad41d66ef30a02b9ca85fc9c95f272257ea9c7a67f21.js
I, [2020-12-15T15:04:43.822864 #374] INFO -- : Writing /var/www/discourse/public/assets/browser-detect-115ab5953de1b5bb122bfb26b757f5391dd8d1d2aef2b81baf7b59aee99d9f34.js
35:M 15 Dec 2020 15:06:27.009 * 10 changes in 300 seconds. Saving...
35:M 15 Dec 2020 15:06:27.010 * Background saving started by pid 1066
1066:C 15 Dec 2020 15:06:27.010 # Failed opening the RDB file dump.rdb (in server root dir /pups) for saving: Permission denied
35:M 15 Dec 2020 15:06:27.110 # Background saving error
35:M 15 Dec 2020 15:06:33.020 * 10 changes in 300 seconds. Saving...
35:M 15 Dec 2020 15:06:33.020 * Background saving started by pid 1067
1067:C 15 Dec 2020 15:06:33.020 # Failed opening the RDB file dump.rdb (in server root dir /pups) for saving: Permission denied
35:M 15 Dec 2020 15:06:33.121 # Background saving error
35:M 15 Dec 2020 15:06:39.030 * 10 changes in 300 seconds. Saving...
35:M 15 Dec 2020 15:06:39.031 * Background saving started by pid 1068
1068:C 15 Dec 2020 15:06:39.031 # Failed opening the RDB file dump.rdb (in server root dir /pups) for saving: Permission denied
35:M 15 Dec 2020 15:06:39.131 # Background saving error
gzip -f -c -9 /var/www/discourse/public/assets/application-42d4413fabab7a4b12e0c25fb01f736af560aa283089071a8493f37c9b042a4a.js > /var/www/discourse/public/assets/application-42d4413fabab7a4b12e0c25fb01f736af560aa283089071a8493f37c9b042a4a.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/application-42d4413fabab7a4b12e0c25fb01f736af560aa283089071a8493f37c9b042a4a.js --output=/var/www/discourse/public/assets/application-42d4413fabab7a4b12e0c25fb01f736af560aa283089071a8493f37c9b042a4a.js.br
35:M 15 Dec 2020 15:06:45.041 * 10 changes in 300 seconds. Saving...
35:M 15 Dec 2020 15:06:45.042 * Background saving started by pid 1072
1072:C 15 Dec 2020 15:06:45.042 # Failed opening the RDB file dump.rdb (in server root dir /pups) for saving: Permission denied
35:M 15 Dec 2020 15:06:45.142 # Background saving error
Done compressing application-42d4413fabab7a4b12e0c25fb01f736af560aa283089071a8493f37c9b042a4a.js : 25.87 secs
Done compressing all JS files : 83.62 secs
Start compiling CSS: 2020-12-15 15:06:49 UTC
Compiling css for default 2020-12-15 15:06:49 UTC
precompile target: desktop Dark
35:M 15 Dec 2020 15:06:51.051 * 10 changes in 300 seconds. Saving...
35:M 15 Dec 2020 15:06:51.051 * Background saving started by pid 1074
1074:C 15 Dec 2020 15:06:51.051 # Failed opening the RDB file dump.rdb (in server root dir /pups) for saving: Permission denied
35:M 15 Dec 2020 15:06:51.151 # Background saving error
rake aborted!
Redis::CommandError: ERR Error running script (call to f_45fe64238f6598e6c505af0aad74b4e178e891f4): @user_script:14: @user_script: 14: -MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.2.5/lib/redis/client.rb:132:in `call'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rack-mini-profiler-2.2.0/lib/mini_profiler/profiling_methods.rb:85:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.2.5/lib/redis.rb:2585:in `block in _eval'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.2.5/lib/redis.rb:69:in `block in synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.2.5/lib/redis.rb:69:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.2.5/lib/redis.rb:2584:in `_eval'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.2.5/lib/redis.rb:2636:in `evalsha'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.4/lib/message_bus/backends/redis.rb:425:in `cached_eval'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.4/lib/message_bus/backends/redis.rb:144:in `publish'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.4/lib/message_bus.rb:382:in `publish'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.4/lib/message_bus/distributed_cache.rb:80:in `publish'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.4/lib/message_bus/distributed_cache.rb:90:in `set'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.4/lib/message_bus/distributed_cache.rb:135:in `[]='
/var/www/discourse/app/models/theme.rb:142:in `get_set_cache'
/var/www/discourse/app/models/theme.rb:158:in `components_for'
/var/www/discourse/app/models/theme.rb:185:in `block in transform_ids'
/var/www/discourse/app/models/theme.rb:177:in `transform_ids'
/var/www/discourse/app/models/theme.rb:371:in `list_baked_fields'
/var/www/discourse/app/models/theme.rb:367:in `resolve_baked_field'
/var/www/discourse/lib/stylesheet/manager.rb:423:in `color_scheme_digest'
/var/www/discourse/lib/stylesheet/manager.rb:361:in `digest'
/var/www/discourse/lib/stylesheet/manager.rb:339:in `stylesheet_filename'
/var/www/discourse/lib/stylesheet/manager.rb:300:in `source_map_filename'
/var/www/discourse/lib/stylesheet/manager.rb:251:in `compile'
/var/www/discourse/lib/stylesheet/manager.rb:169:in `block (2 levels) in precompile_css'
/var/www/discourse/lib/stylesheet/manager.rb:162:in `each'
/var/www/discourse/lib/stylesheet/manager.rb:162:in `block in precompile_css'
/var/www/discourse/lib/stylesheet/manager.rb:161:in `each'
/var/www/discourse/lib/stylesheet/manager.rb:161:in `precompile_css'
/var/www/discourse/lib/tasks/assets.rake:54:in `block (2 levels) in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rails_multisite-2.5.0/lib/rails_multisite/connection_management.rb:76:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rails_multisite-2.5.0/lib/rails_multisite/connection_management.rb:86:in `each_connection'
/var/www/discourse/lib/tasks/assets.rake:47:in `block in <main>'
/var/www/discourse/lib/tasks/assets.rake:331:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => assets:precompile:css
I, [2020-12-15T15:06:53.012968 #1] INFO -- : Downloading MaxMindDB...
Compressing Javascript and Generating Source Maps
I, [2020-12-15T15:06:53.013385 #1] INFO -- : Terminating async processes
I, [2020-12-15T15:06:53.013424 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 35
35:signal-handler (1608044813) Received SIGTERM scheduling shutdown...
35:M 15 Dec 2020 15:06:53.054 # User requested shutdown...
35:M 15 Dec 2020 15:06:53.054 * Saving the final RDB snapshot before exiting.
35:M 15 Dec 2020 15:06:53.054 # Failed opening the RDB file dump.rdb (in server root dir /pups) for saving: Permission denied
35:M 15 Dec 2020 15:06:53.054 # Error trying to save the DB, can't exit.
35:M 15 Dec 2020 15:06:53.054 # SIGTERM received but errors trying to shut down the server, check the logs for more information
35:M 15 Dec 2020 15:06:57.060 * 10 changes in 300 seconds. Saving...
35:M 15 Dec 2020 15:06:57.060 * Background saving started by pid 1078
1078:C 15 Dec 2020 15:06:57.061 # Failed opening the RDB file dump.rdb (in server root dir /pups) for saving: Permission denied
35:M 15 Dec 2020 15:06:57.161 # Background saving error
I, [2020-12-15T15:07:03.014092 #1] INFO -- : exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid:35 did not terminate cleanly, forcing termination!
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 372 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
be9c92f00a4814e5e9ebcdb06f25232b03f7522390b97c157085c2f7ef7f3387
간결하게 말하자면, 저는 다음과 같은 오류를 보고 있습니다.
rake aborted!
제 app.yaml 파일은 다음과 같습니다.
templates:
env:
LANG: en_US.UTF-8
UNICORN_WORKERS: 8
DISCOURSE_DB_USERNAME: discourse
DISCOURSE_DB_PASSWORD: "xxxxx"
DISCOURSE_DB_HOST: "xxxxx"
DISCOURSE_REDIS_HOST: 127.0.0.1
DISCOURSE_REDIS_PORT: "6379"
DISCOURSE_DB_NAME: discourse_prod_2
DISCOURSE_DEVELOPER_EMAILS: 'xxxxxxx'
DISCOURSE_HOSTNAME: 'localhost'
DISCOURSE_DB_PORT: "5301"
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- mkdir -p plugins
- git clone https://github.com/discourse/discourse-solved.git
- git clone https://github.com/discourse/discourse-voting.git
- git clone https://github.com/discourse/discourse-slack-official.git
- git clone https://github.com/discourse/discourse-assign.git
run:
- exec:
cd: /var/www/discourse
cmd:
- sed -i 's/GlobalSetting.serve_static_assets/true/' config/environments/production.rb
보안을 위해 비밀번호, 호스트명, 이메일은 숨겼습니다. Redis는 별도의 Docker 컨테이너를 실행하고 있습니다. localhost와 지정된 포트에서 연결할 수 있습니다.
무엇을 놓치고 있는지 알려주시면 좋겠습니다.
