Discourse에서 추가 플러그인을 제공하는 Docker 컨테이너를 구축하고 있습니다: GitHub - Monogramm/docker-bitnami-discourse: 🐋 Custom Discourse Bitnami image with additional plugins and tools. · GitHub.
컨테이너를 단독으로 빌드할 때, bundle exec rake assets:precompile이 Redis에 연결을 시도하다가 실패합니다:
[0m[91m+ [0m[91mbundle[0m[91m exec[0m[91m rake[0m[91m assets:precompile[0m[91m
[0m[91mFailed to report error: Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL) 2 Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL) subscribe failed, reconnecting in 1 second. Call stack ["/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis/client.rb:362:in `rescue in establish_connection'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis/client.rb:343:in `establish_connection'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis/client.rb:107:in `block in connect'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis/client.rb:308:in `with_reconnect'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis/client.rb:106:in `connect'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis/client.rb:289:in `with_socket_timeout'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis/client.rb:139:in `call_loop'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis/subscribe.rb:44:in `subscription'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis/subscribe.rb:14:in `subscribe'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis.rb:3506:in `_subscription'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis.rb:2326:in `block in subscribe'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis.rb:69:in `block in synchronize'", "/opt/bitnami/ruby/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis.rb:69:in `synchronize'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/redis-4.2.1/lib/redis.rb:2325:in `subscribe'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-3.3.1/lib/message_bus/backends/redis.rb:287:in `global_subscribe'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-3.3.1/lib/message_bus.rb:754:in `global_subscribe_thread'", "/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-3.3.1/lib/message_bus.rb:702:in `block in new_subscriber_thread'"]
[0m[91mrake aborted!
[0m[91mPG::ConnectionBad: could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
[0m[91m/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/pg-1.2.3/lib/pg.rb:58:in `initialize'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/pg-1.2.3/lib/pg.rb:58:in `new'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/pg-1.2.3/lib/pg.rb:58:in `connect'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/postgresql_adapter.rb:46:in `postgresql_connection'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:887:in `new_connection'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:931:in `checkout_new_connection'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:910:in `try_to_checkout_new_connection'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:871:in `acquire_connection'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:593:in `checkout'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:437:in `connection'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:1119:in `retrieve_connection'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.1/lib/active_record/connection_handling.rb:221:in `retrieve_connection'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.1/lib/active_record/connection_handling.rb:189:in `connection'
/opt/bitnami/discourse/lib/site_settings/db_provider.rb:61:in `table_exists?'
/opt/bitnami/discourse/lib/site_settings/db_provider.rb:16:in `all'
/opt/bitnami/discourse/lib/site_settings/defaults_provider.rb:29:in `db_all'
/opt/bitnami/discourse/lib/site_setting_extension.rb:287:in `block in refresh!'
/opt/bitnami/discourse/lib/site_setting_extension.rb:284:in `synchronize'
/opt/bitnami/discourse/lib/site_setting_extension.rb:284:in `refresh!'
/opt/bitnami/discourse/lib/site_setting_extension.rb:505:in `block in setup_methods'
/opt/bitnami/discourse/config/initializers/004-message_bus.rb:120:in `<main>'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:55:in `load'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/dependencies.rb:318:in `block in load'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/dependencies.rb:291:in `load_dependency'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/dependencies.rb:318:in `load'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/engine.rb:666:in `block in load_config_initializer'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/notifications.rb:182:in `instrument'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/engine.rb:665:in `load_config_initializer'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/engine.rb:625:in `block (2 levels) in <class:Engine>'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/engine.rb:624:in `each'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/engine.rb:624:in `block in <class:Engine>'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/initializable.rb:32:in `instance_exec'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/initializable.rb:32:in `run'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/initializable.rb:61:in `block in run_initializers'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/initializable.rb:50:in `each'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/initializable.rb:50:in `tsort_each_child'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/initializable.rb:60:in `run_initializers'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/application.rb:363:in `initialize!'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/railtie.rb:190:in `public_send'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/railtie.rb:190:in `method_missing'
/opt/bitnami/discourse/config/environment.rb:7:in `<main>'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/kernel.rb:23:in `require'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/dependencies.rb:324:in `block in require'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/dependencies.rb:324:in `require'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/application.rb:339:in `require_environment!'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/application.rb:523:in `block in run_tasks_blocks'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-rails-3.2.1/lib/sprockets/rails/task.rb:62:in `block (2 levels) in define'
/opt/bitnami/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
/opt/bitnami/ruby/bin/bundle:23:in `load'
/opt/bitnami/ruby/bin/bundle:23:in `<main>'
[0m[91mTasks: TOP => environment
[0m[91m(See full trace by running task with --trace)
[0mThe command '/bin/sh -c set -ex; bundle exec rake plugin:install[https://github.com/jonmbake/discourse-ldap-auth]; bundle exec rake plugin:install[https://github.com/discourse/discourse-adplugin]; bundle exec rake plugin:install[https://github.com/discourse/discourse-affiliate]; bundle exec rake plugin:install[https://github.com/discourse/discourse-akismet]; bundle exec rake plugin:install[https://github.com/discourse/discourse-auto-deactivate]; bundle exec rake plugin:install[https://github.com/discourse/discourse-bbcode]; bundle exec rake plugin:install[https://github.com/discourse/discourse-bbcode-color]; bundle exec rake plugin:install[https://github.com/discourse/discourse-cakeday]; bundle exec rake plugin:install[https://github.com/discourse/discourse-canned-replies]; bundle exec rake plugin:install[https://github.com/discourse/discourse-characters-required]; bundle exec rake plugin:install[https://github.com/discourse/discourse-chat-integration]; bundle exec rake plugin:install[https://github.com/discourse/discourse-checklist]; bundle exec rake plugin:install[https://github.com/discourse/discourse-data-explorer]; bundle exec rake plugin:install[https://github.com/discourse/discourse-fingerprint]; bundle exec rake plugin:install[https://github.com/discourse/discourse-footnote]; bundle exec rake plugin:install[https://github.com/discourse/discourse-graphviz]; bundle exec rake plugin:install[https://github.com/discourse/discourse-math]; bundle exec rake plugin:install[https://github.com/discourse/discourse-matomo-analytics]; bundle exec rake plugin:install[https://github.com/discourse/discourse-oauth2-basic]; bundle exec rake plugin:install[https://github.com/discourse/discourse-patreon]; bundle exec rake plugin:install[https://github.com/discourse/discourse-plugin-linkedin-auth]; bundle exec rake plugin:install[https://github.com/discourse/discourse-push-notifications]; bundle exec rake plugin:install[https://github.com/discourse/discourse-saved-searches]; bundle exec rake plugin:install[https://github.com/discourse/discourse-signatures]; bundle exec rake plugin:install[https://github.com/discourse/discourse-sitemap]; bundle exec rake plugin:install[https://github.com/discourse/discourse-staff-notes]; bundle exec rake plugin:install[https://github.com/discourse/discourse-styleguide]; bundle exec rake plugin:install[https://github.com/discourse/discourse-tooltips]; bundle exec rake plugin:install[https://github.com/discourse/discourse-user-card-badges]; bundle exec rake plugin:install[https://github.com/discourse/discourse-voting]; bundle exec rake assets:precompile' returned a non-zero code: 1
build hook failed! (1)
