Can't rebuild app 'bundle exec rake db:migrate' failed
A user encountered an error while rebuilding their Discourse app using ./launcher rebuild app, which failed during bundle exec rake db:migrate due to a gem version conflict: public_suffix-2.0.5 was being activated while public_suffix-3.0.2 was already loaded. The error originated from the discourse-backups-to-dropbox plugin as noted by tgxworld, which required an outdated gem version incompatible with the current Discourse setup. Attempts to resolve it—including running git pull and ./discourse-doctor—failed as reported by the user. Additional logs revealed missing directories (e.g., /shared/log/rails) and PostgreSQL version mismatches (expected v10, found v9.5) user. Manual Rails server startup inside the container also failed with the same gem conflict user. Ultimately, the user resolved the issue by removing the problematic plugin, after which the app rebuilt successfully user. Community advice emphasized using Docker for official support Mittineague and checking directory permissions JagWaugh.
hi.
when running command:
output error:
    I, [2018-07-26T07:19:47.246135 #15]  INFO -- : > cd /var/www/discourse && su discourse -c
   rake aborted!
   Gem::LoadError: can't activate public_suffix-2.0.5, already activated public_suffix-3.0.2
   /var/www/discourse/lib/plugin_gem.rb:18:in `load'
   /var/www/discourse/lib/plugin/instance.rb:528:in `gem'
   /var/www/discourse/plugins/discourse-backups-to-dropbox/plugin.rb:7:in `activate!'
   /var/www/discourse/lib/plugin/instance.rb:458:in `instance_eval'
   /var/www/discourse/lib/plugin/instance.rb:458:in `activate!'
   /var/www/discourse/lib/discourse.rb:151:in `block in activate_plugins!'
   /var/www/discourse/lib/discourse.rb:148:in `each'
   /var/www/discourse/lib/discourse.rb:148:in `activate_plugins!'
   /var/www/discourse/config/application.rb:220:in `<class:Application>'
   /var/www/discourse/config/application.rb:39:in `<module:Discourse>'
   /var/www/discourse/config/application.rb:38:in `<top (required)>'
   /var/www/discourse/Rakefile:5:in `require'
   /var/www/discourse/Rakefile:5:in `<top (required)>'
   /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rake-12.3.1/exe/rake:27:in `<top (required)>'
   /usr/local/bin/bundle:23:in `load'
   /usr/local/bin/bundle:23:in `<main>'
   I, [2018-07-26T07:19:59.271510 #15]  INFO -- : gem install public_suffix -v 2.0.5 -i
   /var/www/discourse/plugins/discourse-backups-to-dropbox/gems/2.5.1 --no-document --ignore-
   dependencies
   Successfully installed public_suffix-2.0.5
    1 gem installed
   I, [2018-07-26T07:19:59.271967 #15]  INFO -- : Terminating async processes
   I, [2018-07-26T07:19:59.272020 #15]  INFO -- : Sending INT to HOME=/var/lib/postgresql
   USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert
   /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main pid: 70
I, [2018-07-26T07:19:59.272091 #15]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 186
2018-07-26 07:19:59.272 UTC [70] LOG:  received fast shutdown request
186:signal-handler (1532589599) Received SIGTERM scheduling shutdown...
186:M 26 Jul 07:19:59.302 # User requested shutdown...
186:M 26 Jul 07:19:59.302 * Saving the final RDB snapshot before exiting.
2018-07-26 07:19:59.307 UTC [70] LOG:  aborting any active transactions
2018-07-26 07:19:59.310 UTC [70] LOG:  worker process: logical replication launcher (PID 79) exited with exit code 1
2018-07-26 07:19:59.312 UTC [74] LOG:  shutting down
186:M 26 Jul 07:19:59.758 * DB saved on disk
186:M 26 Jul 07:19:59.758 # Redis is now ready to exit, bye bye...
2018-07-26 07:19:59.936 UTC [70] LOG:  database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 516 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
3e928907050fb426a1cac25c785ce78f90291a0be2793f0168340e48125bca0b
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
can't rebuild app
output command:
    root@ubuntu:/var/discourse# docker images
    REPOSITORY             TAG                 IMAGE ID            CREATED             SIZE
   discourse/base         2.0.20180717        3af2eb204be0        8 days ago          1.71GB
   local_discourse/app    latest              8171651e3173        3 months ago        2.92GB
   discourse/base         2.0.20171231        3925ef3919cc        6 months ago        1.73GB
   samsaffron/docker-gc   latest              54ca424ca8d6        2 years ago         57.7MB
   root@ubuntu:/var/discourse# docker ps
   CONTAINER ID        IMAGE               COMMAND             CREATED             STATUS
   PORTS               NAMES
thanks
Try
git pull
./discourse-doctor
Trying to throw but still faces the error:
    FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 520 exit 1>
d7394631501352d1b02a5cef05b5fc5c3f7755636f9d89e2919648b22dfde6a8
==================== END REBUILD LOG ====================
thanks
@Falco It looks like this line needs to be updated to maintain compatibility with the latest version of Discourse.
app logs:
ok: run: postgres: (pid 210) 0s
chown: cannot access '/shared/log/rails': No such file or directory
supervisor pid: 207 unicorn pid: 213
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:805:in `initialize': No such file or directory @ rb_sysopen - /var/www/discourse/log/unicorn.stderr.log (Errno::ENOENT)
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:805:in `open'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:805:in `redirect_io'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:174:in `stderr_path='
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/configurator.rb:120:in `block in commit!'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/configurator.rb:117:in `each'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/configurator.rb:117:in `commit!'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:104:in `initialize'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/bin/unicorn:126:in `new'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `load'
	from /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `<main>'
config/unicorn_launcher: line 44: kill: (213) - No such process
config/unicorn_launcher: line 10: kill: (213) - No such process
exiting
ok: run: redis: (pid 48) 94s
ok: run: postgres: (pid 222) 1s
supervisor pid: 217 unicorn pid: 225
config/unicorn_launcher: line 44: kill: (225) - No such process
config/unicorn_launcher: line 10: kill: (225) - No such process
exiting
ok: run: redis: (pid 48) 98s
timeout: down: postgres: 0s, normally up, want up
ok: run: redis: (pid 48) 105s
ok: run: postgres: (pid 247) 0s
supervisor pid: 239 unicorn pid: 250
config/unicorn_launcher: line 44: kill: (250) - No such process
config/unicorn_launcher: line 10: kill: (250) - No such process
exiting
ok: run: redis: (pid 48) 112s
ok: run: redis: (pid 48) 120s
ok: run: postgres: (pid 269) 0s
supervisor pid: 264 unicorn pid: 272
config/unicorn_launcher: line 44: kill: (272) - No such process
config/unicorn_launcher: line 10: kill: (272) - No such process
exiting
supervisor pid: 335 unicorn pid: 342
config/unicorn_launcher: line 44: kill: (342) - No such process
config/unicorn_launcher: line 10: kill: (342) - No such process
exiting
ok: run: redis: (pid 48) 153s
ok: run: postgres: (pid 349) 0s
supervisor pid: 346 unicorn pid: 352
config/unicorn_launcher: line 44: kill: (352) - No such process
config/unicorn_launcher: line 10: kill: (352) - No such process
exiting
ok: run: redis: (pid 48) 159s
timeout: down: postgres: 1s, normally up, want up
ok: run: redis: (pid 48) 166s
ok: run: postgres: (pid 380) 0s
supervisor pid: 377 unicorn pid: 383
config/unicorn_launcher: line 44: kill: (383) - No such process
config/unicorn_launcher: line 10: kill: (383) - No such process
exiting
ok: run: redis: (pid 48) 169s
ok: run: postgres: (pid 386) 0s
supervisor pid: 387 unicorn pid: 392
config/unicorn_launcher: line 44: kill: (392) - No such process
config/unicorn_launcher: line 10: kill: (392) - No such process
exiting
ok: run: redis: (pid 48) 170s
ok: run: postgres: (pid 401) 0s
supervisor pid: 396 unicorn pid: 404
config/unicorn_launcher: line 44: kill: (404) - No such process
config/unicorn_launcher: line 10: kill: (404) - No such process
exiting
ok: run: redis: (pid 48) 174s
ok: run: postgres: (pid 407) 0s
supervisor pid: 408 unicorn pid: 413
config/unicorn_launcher: line 44: kill: (413) - No such process
config/unicorn_launcher: line 10: kill: (413) - No such process
exiting
ok: run: redis: (pid 48) 175s
ok: run: postgres: (pid 421) 0s
supervisor pid: 416 unicorn pid: 424
config/unicorn_launcher: line 44: kill: (424) - No such process
config/unicorn_launcher: line 10: kill: (424) - No such process
exiting
ok: run: redis: (pid 48) 179s
ok: run: postgres: (pid 435) 0s
supervisor pid: 428 unicorn pid: 438
config/unicorn_launcher: line 44: kill: (438) - No such process
config/unicorn_launcher: line 10: kill: (438) - No such process
exiting
ok: run: redis: (pid 48) 185s
ok: run: postgres: (pid 451) 0s
supervisor pid: 444 unicorn pid: 454
config/unicorn_launcher: line 44: kill: (454) - No such process
config/unicorn_launcher: line 10: kill: (454) - No such process
exiting
ok: run: redis: (pid 48) 191s
ok: run: postgres: (pid 466) 0s
supervisor pid: 457 unicorn pid: 469
config/unicorn_launcher: line 44: kill: (469) - No such process
config/unicorn_launcher: line 10: kill: (469) - No such process
exiting
ok: run: redis: (pid 48) 199s
ok: run: redis: (pid 48) 206s
ok: run: postgres: (pid 489) 0s
supervisor pid: 482 unicorn pid: 492
config/unicorn_launcher: line 44: kill: (492) - No such process
config/unicorn_launcher: line 10: kill: (492) - No such process
exiting
ok: run: redis: (pid 48) 212s
ok: run: postgres: (pid 500) 0s
supervisor pid: 496 unicorn pid: 503
config/unicorn_launcher: line 44: kill: (503) - No such process
config/unicorn_launcher: line 10: kill: (503) - No such process
exiting
ok: run: redis: (pid 48) 216s
Shutting Down
run-parts: executing /etc/runit/3.d/01-nginx
ok: down: nginx: 1s, normally up
run-parts: executing /etc/runit/3.d/02-unicorn
ok: down: unicorn: 0s, normally up
run-parts: executing /etc/runit/3.d/10-redis
timeout: run: redis: (pid 48) 224s, want down, got TERM
run-parts: /etc/runit/3.d/10-redis exited with return code 1
run-parts: executing /etc/runit/3.d/99-postgres
ok: down: postgres: 1s, normally up, want up
When using programs that use GNU Parallel to process data for publication please cite:
  O. Tange (2011): GNU Parallel - The Command-Line Power Tool,
  ;login: The USENIX Magazine, February 2011:42-47.
This helps funding further development; and it won't cost you a cent.
Or you can get GNU Parallel without this requirement by paying 10000 EUR.
To silence this citation notice run 'parallel --bibtex' once or use '--no-notice'.
ok: down: nginx: 9s, normally up
ok: down: cron: 1s, normally up
run-parts: executing /etc/runit/1.d/00-ensure-links
run-parts: executing /etc/runit/1.d/00-fix-var-logs
run-parts: executing /etc/runit/1.d/anacron
anacron: Can't chdir to /var/spool/anacron: No such file or directory
run-parts: /etc/runit/1.d/anacron exited with return code 1
Started runsvdir, PID is 28
fail: redis: runsv not running
rsyslogd: command 'KLogPermitNonKernelFacility' is currently not permitted - did you already set it via a RainerScript command (v6+ config)? [v8.16.0 try http://www.rsyslog.com/e/2222 ]
rsyslogd: imklog: cannot open kernel log (/proc/kmsg): Operation not permitted.
rsyslogd: activation of module imklog failed [v8.16.0 try http://www.rsyslog.com/e/2145 ]
rsyslogd: Could not open output pipe '/dev/xconsole':: No such file or directory [v8.16.0 try http://www.rsyslog.com/e/2039 ]
timeout: down: redis: 0s, normally up, want up
timeout: down: redis: 1s, normally up, want up
Shutting Down
ok: down: nginx: 0s, normally up
ok: down: unicorn: 1s, normally up
ok: down: redis: 1s, normally up, want up
exiting
ok: run: redis: (pid 38) 520s
ok: run: redis: (pid 38) 527s
ok: run: redis: (pid 38) 535s
ok: run: redis: (pid 38) 542s
ok: run: redis: (pid 38) 550s
ok: run: redis: (pid 38) 557s
ok: run: postgres: (pid 1578) 1s
supervisor pid: 1570 unicorn pid: 1581
config/unicorn_launcher: line 44: kill: (1581) - No such process
config/unicorn_launcher: line 10: kill: (1581) - No such process
If I want to run the project without a docker
How can I transfer data?
You want to not do that.
discourse/docs/INSTALL.md at main · discourse/discourse · GitHub
:bell: The only officially supported installs of Discourse are Docker based. You must have SSH access to a 64-bit Linux server with Docker support . We regret that we cannot support any other methods of installation including cpanel, plesk, webmin, etc.
What happened to your /var/discourse/shared/standalone/log/rails directory?
logs:
root@ubuntu:/var/discourse/shared/standalone/log/rails# tail -f production.log
Error connecting to Redis on localhost:6379 (Errno::ECONNREFUSED) subscribe failed, reconnecting in 1 second. Call stack ["/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis/client.rb:345:in `rescue in establish_connection'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis/client.rb:331:in `establish_connection'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis/client.rb:101:in `block in connect'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis/client.rb:293:in `with_reconnect'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis/client.rb:100:in `connect'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis/client.rb:276:in `with_socket_timeout'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis/client.rb:133:in `call_loop'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis/subscribe.rb:43:in `subscription'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis/subscribe.rb:12:in `subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis.rb:2775:in `_subscription'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis.rb:2143:in `block in subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis.rb:58:in `block in synchronize'", "/usr/local/lib/ruby/2.4.0/monitor.rb:214:in `mon_synchronize'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis.rb:58:in `synchronize'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/redis-3.3.5/lib/redis.rb:2142:in `subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.2/lib/message_bus/backends/redis.rb:336:in `global_subscribe'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.2/lib/message_bus.rb:525:in `global_subscribe_thread'", "/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.2/lib/message_bus.rb:473:in `block in new_subscriber_thread"]
During the great effort, I realized that the project needs a PG version 10, and the version that it installs is version 9.5.
The following report is from the PG inside the container
2018-07-27 08:49:27.569 UTC [2144] HINT:  You might need to initdb.
2018-07-27 08:49:28.583 UTC [2146] FATAL:  "/shared/postgres_data" is not a valid data directory
2018-07-27 08:49:28.583 UTC [2146] DETAIL:  File "/shared/postgres_data/PG_VERSION" does not contain valid data.
2018-07-27 08:49:28.583 UTC [2146] HINT:  You might need to initdb.
How can I run the project inside the container manually?
thanks
hi.
When we manually execute the project into the container, we will be eating the following:
root@ubuntu-app:/var/www/discourse# bundle exec rails s -b 0.0.0.0:3000
Traceback (most recent call last):
	24: from bin/rails:4:in `<main>'
	23: from bin/rails:4:in `require'
	22: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/commands.rb:18:in `<top (required)>'
	21: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/command.rb:46:in `invoke'
	20: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/command/base.rb:65:in `perform'
	19: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/thor-0.19.4/lib/thor.rb:369:in `dispatch'
	18: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/thor-0.19.4/lib/thor/invocation.rb:126:in `invoke_command'
	17: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/thor-0.19.4/lib/thor/command.rb:27:in `run'
	16: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/commands/server/server_command.rb:142:in `perform'
	15: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/commands/server/server_command.rb:142:in `tap'
	14: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/commands/server/server_command.rb:145:in `block in perform'
	13: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/commands/server/server_command.rb:145:in `require'
	12: from /var/www/discourse/config/application.rb:38:in `<top (required)>'
	11: from /var/www/discourse/config/application.rb:39:in `<module:Discourse>'
	10: from /var/www/discourse/config/application.rb:220:in `<class:Application>'
	 9: from /var/www/discourse/lib/discourse.rb:148:in `activate_plugins!'
	 8: from /var/www/discourse/lib/discourse.rb:148:in `each'
	 7: from /var/www/discourse/lib/discourse.rb:151:in `block in activate_plugins!'
	 6: from /var/www/discourse/lib/plugin/instance.rb:457:in `activate!'
	 5: from /var/www/discourse/lib/plugin/instance.rb:457:in `instance_eval'
	 4: from /var/www/discourse/plugins/discourse-backups-to-dropbox/plugin.rb:7:in `activate!'
	 3: from /var/www/discourse/lib/plugin/instance.rb:527:in `gem'
	 2: from /var/www/discourse/lib/plugin_gem.rb:18:in `load'
	 1: from /usr/local/lib/ruby/site_ruby/2.5.0/rubygems/specification.rb:1437:in `activate'
/usr/local/lib/ruby/site_ruby/2.5.0/rubygems/specification.rb:2322:in `check_version_conflict': can't activate public_suffix-2.0.5, already activated public_suffix-3.0.2 (Gem::LoadError)
[solved] I found the problem
The problem with the plugin is discourse-backups-to-dropbox
Removed the plugin and the project fared well.
thanks
