LDAP plugin always auth_overrides_username
We habe a serious issue after updating to the latest 2.8.0.Beta10: disabling the setting
seems to have no effect. The box is unchecked, but after every Logout/Login process, the user-selected username is overwritten with the LDAP name. Can someone confirm this?
At the moment the LDAP plugin specifically enables the overrides_username setting. Maybe it should simply rely on core’s auth_overrides_username setting, or introduce a new site setting.
The LDAP plugin is not an official plugin, and I don’t think the author is active here on Meta, so you might need to open an issue on the repository.
Thanks for the quick response. Is this already solved by this PR?
https://github.com/jonmbake/discourse-ldap-auth/pull/67
That won’t fix it. Although now that you mention it, that PR probably introduced this behaviour change.
Some context: we removed an old ‘omit username’ flag from core, which the LDAP plugin was using. It was extremely similar to the overrides_username setting, which is why I simply substituted them in the LDAP plugin. However, as you’ve noticed, omit_username only applied during initial signup, while overrides_username applies on every login.
Here’s a PR to reverse that behaviour change. We’ll need @jonmbake to merge
https://github.com/jonmbake/discourse-ldap-auth/pull/69
@Ralf_Stockmann that PR is now merged, so the old behaviour should be restored once you update the plugin
