שגיאת תוסף LDAP? לאחר עדכון לגרסה האחרונה של Discourse
סיכום מבוסס בינה מלאכותית
After updating to the latest version of Discourse, Yusa_Arifki is experiencing issues with the LDAP plugin. Despite disabling the plugin, the LDAP login button remains functional. Canapin identified the plugin being used as discourse-ldap-auth from GitHub. Canapin suggested contacting the author directly, as it’s an unofficial plugin. JammyDodger mentioned that Benjamin_D and jonmbake previously fixed issues with the plugin and might be able to help again. Benjamin_D provided a code snippet indicating that the plugin’s enabled? method relies on SiteSetting.ldap_enabled, which might be causing the issue.
Hello everyone, i just finished updating my discourse to latest version. But somehow the ldap plugin is not matched with how i configured
  1. ldap
    currently i disabled ldap plugin, but somehow when people try to login the ldap button still exist and still functional
Hello,
Is that the plugin you’re using?
https://github.com/jonmbake/discourse-ldap-auth
im not sure, but here is how it displayed on the plugin page
Yes, that seems to be the one.
I didn’t find it in Customization > Plugin. It’s unofficial. I suggest you to contact the author directly, but maybe someone who also use it will have an idea here. :slight_smile:
I think @Benjamin_D and @jonmbake fixed it up last time it needed a tweak, so will hopefully do the same again. :crossed_fingers:
ah yes, isn’t supposed to work :
          def enabled?
will do it
