ich habe fast alles befolgt und hinzugefügt (LDAP-Plugin und LDAP-Konfiguration unter /admin/site_settings/category/ldap), wie in den folgenden Links beschrieben, um LDAP für Discourse einzurichten:
Aber ich kann die LDAP-Option auf der Anmeldeseite immer noch nicht sehen.
Könnten Sie mir bitte mitteilen, ob weitere Anweisungen befolgt werden müssen, um die LDAP-Option auf der Anmeldeseite zu erhalten?
I can directly access with “https://discourse-xxx.xxx/auth/ldap” for LDAP login, but I don’t see LDAP pop up after clicking on login button ( as shown in below screen shot).
Can any one please let me know if I will need to modify the Login form in the initial Discourse page to include an extra button that can allow me to redirect to “https://discourse-xxx.xx/auth/ldap”.
I have installed Discourse in Ubuntu Ubuntu 16.04.3 server and the Discourse version is v2.0.0.beta10
Yes, I have enabled the LDAP plugin and did the basic configuration, which is why I was able to do LDAP authentication with direct URL (“https://discourse-xxx.xxx/auth/ldap” )as mentioned in above posts.
Uncaught TypeError: Cannot read property ‘addPreProcessor’ of undefined
at _plugin-third-party-bbf5e2e3e7e7a22c7391a8d01a610ce18dd03367259d13426ed3751e26a14552.js:23
at _plugin-third-party-bbf5e2e3e7e7a22c7391a8d01a610ce18dd03367259d13426ed3751e26a14552.js:24
We don’t have that in our setup. The JS error should be solved, that’s probably causing the page to not render properly.
@pprp
Please share the installed plugin lines from your app.yml and any modifications you’ve made to your theme with custom JS in the header, footer, etc. sections.
I’d say you disable the jira and abbreviation plugins one by one and try to eliminate the error (each line removal with an app rebuild). Those plugins look dated, last commit was 2016. Not sure if they’re still compatible with Discourse, nor if they’re supported.
The abbreviation and jira onebox plugins for example were moved to #plugin:broken-plugin in 2016.
Theme customization happens in the frontend in your admin console, /admin/customize/themes. I doubt that this helps though as you’re using plugins which seem broken.
