Let’s Encrypt problem after upgrading to 1.9.0.beta3
After upgrading to 1.9.0.beta3, saluzi noticed their SSL rating dropped from A+ to A due to an issue with HTTP Strict Transport Security (HSTS). mpalmer investigated and found that saluzi’s site was not sending an HSTS header at all.
codinghorror initially reported that HSTS was working fine on their self-hosted Discourse install. However, mpalmer later discovered that codinghorror’s site was also not sending an HSTS header.
Falco admitted to making a mistake when adding the Referrer-Policy header, which caused the issue. Falco provided a fix, and codinghorror confirmed that HSTS is now working correctly again.
After upgrading to 1.9.0.beta3 , the SSL(Let’s Encrypt) rating has changed from A+ to A,the problem is HSTS.
Thanks very much
1 me gusta
What is the problem with HSTS?
Using the ssllabs.com query, HTTP Strict Transport Security (HSTS) with long duration deployed on this server this sentence disappears . Thank you.
The default HSTS configuration is compliant with the SSL Labs recommendations. What site are you testing, and what changes have you made to the default discourse_docker templates?
I have nothing to change, completely default. My website is https://www.xxxx.com/
Your site is not sending an HSTS header at all. You’re also sending a header that was reverted from the default template nine days ago. Whatever you’re doing over there, it isn’t what we recommend.
4 Me gusta
Working fine on my self hosted by the book install of Discourse
3 Me gusta
Hmm, plausible, as I did a command line rebuild yesterday cc @falco.
1 me gusta
Can confirm discourse.codinghorror.com is no longer sending a HSTS header at all:
$ wget -O /dev/null -S https://discourse.codinghorror.com -q
  HTTP/1.1 200 OK
  Server: nginx
  Date: Thu, 13 Jul 2017 22:04:15 GMT
  Content-Type: text/html; charset=utf-8
  Transfer-Encoding: chunked
  Connection: keep-alive
  Vary: Accept-Encoding
  X-Frame-Options: SAMEORIGIN
  X-XSS-Protection: 1; mode=block
  X-Content-Type-Options: nosniff
  X-Discourse-Route: list/latest
  Cache-Control: no-store, must-revalidate, no-cache, private
  X-Discourse-Cached: true
  X-Request-Id: f40d4ea9-375a-4a9e-b6e1-c7500ffa194f
  X-Runtime: 0.002585
  X-Discourse-TrackView: 1
  Referrer-Policy: no-referrer-when-downgrade
2 Me gusta
Yeah, I made a mistake when I added the Referrer-Policy header.
nginx add_header lack of support for inheritance got me there.
Will fix soon.
9 Me gusta
Awwwwwwww yeah… we’ve all been to that circle of hell.
6 Me gusta
Rebuild a site to test this in action:
https://github.com/discourse/discourse_docker/commit/42504d319c1c7abe8501e8db4efcf1707aaaa240
6 Me gusta
It works!
Thanks for the report @saluzi this was a definite regression.
8 Me gusta
