Continuing the discussion from Setting up Let’s Encrypt with Multiple Domains :
Hi!
I tried this how to but nothing changed and /etc/runit/1.d/letsencrypt is not modified.
I’ve 2 containers (data.yml) and web.yml and want to use multisite config.
Here the after_ssl I used (from Set up Let’s Encrypt with multiple domains / redirects - #15 ):
after_ssl:
- replace:
filename: "/etc/runit/1.d/letsencrypt"
to: |
-d forum.test.com -d forum2.test.com -d forum-test.test.com -k 4096 -w /var/www/discourse/public
- replace:
from: /-k 4096 --force -w \/var\/www\/discourse\/public/
to: |
-d forum.test.com -d forum2.test.com -d forum-test.test.com -k 4096 --force -w /var/www/discourse/public
The only discourse the default one (DISCOURSE_HOSTNAME).
For the other one, I get the following error when I do a curl:
curl: (51) SSL: no alternative certificate subject name matches target host name 'forum-test.test.com'
brahn
(Brahn)
13 ביולי, 2018, 12:12am
Which yml did you add the after_ssl to?
Also, one of those links about let’s encrypt describes how to inspect the logs of the script, perhaps some in there will help diagnose.
I added it to web_only.yml
brahn
(Brahn)
13 ביולי, 2018, 9:44am
4
web.yml or web_only.yml?
What is the launcher command you are using when doing the rebuild?
I renamed it web_pe.yml. So I’m using ./launcher rebuild web_pe
brahn
(Brahn)
13 ביולי, 2018, 10:18am
6
I can’t see any recent changes that would stop the regex in the from working but obviously something is not right. Is there anything unusual in the templates: of your web_pe.yml that could be altering the base ssl before the after_ssl happens?
CamilleRoux
(Camille Roux)
20 באוגוסט, 2018, 2:05am
7
Hi,
No, here is the templates: of my web_pe.yml:
templates:
- "templates/web.ssl.template.yml"
- "templates/web.letsencrypt.ssl.template.yml"
Here is the after_ssl hook I have in web_pe.yml:
after_ssl:
- replace:
to: |
-d forum.pragmaticentrepreneurs.com -d forum.noschangements.fr -k 4096 -w /var/www/discourse/public
- replace:
to: |
-d forum.pragmaticentrepreneurs.com -d forum.noschangements.fr -k 4096 --force -w /var/www/discourse/public
Here are the logs during the bootstrap:
I, [2018-08-20T01:52:07.061735 #13] INFO -- : Replacing (?-mix:-k 4096 -w \/var\/www\/discourse\/public) with -d forum.pragmaticentrepreneurs.com -d forum.noschangements.fr -k 4096 -w /var/www/discourse/public
in /etc/runit/1.d/letsencrypt
I, [2018-08-20T01:52:07.062730 #13] INFO -- : Replacing (?-mix:-k 4096 --force -w \/var\/www\/discourse\/public) with -d forum.pragmaticentrepreneurs.com -d forum.noschangements.fr -k 4096 --force -w /var/www/discourse/public
Here is the etc/nginx/letsencrypt.conf
LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh --issue -d forum.pragmaticentrepreneurs.com -k 4096 -w /var/www/discourse/public
if [ ! "$(cd /shared/letsencrypt/forum.pragmaticentrepreneurs.com && openssl verify -CAfile ca.cer fullchain.cer | grep "OK")" ]; then
# Try to issue the cert again if something goes wrong
LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh --issue -d forum.pragmaticentrepreneurs.com -k 4096 --force -w /var/www/discourse/public
fi
LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh --installcert -d forum.pragmaticentrepreneurs.com --fullchainpath /shared/ssl/forum.pragmaticentrepreneurs.com.cer --keypath /shared/ssl/forum.pragmaticentrepreneurs.com.key --reloadcmd "sv reload nginx"
The last line should be modified, shouldn’t be?
brahn
(Brahn)
20 באוגוסט, 2018, 2:31am
8
No, the file that gets modified in the container is /etc/runit/1.d/letsencrypt.
CamilleRoux
(Camille Roux)
20 באוגוסט, 2018, 8:30am
9
Ok! So here is the /etc/runit/1.d/letsencrypt file of my web container:
# cat /etc/runit/1.d/letsencrypt
#!/bin/bash
/usr/sbin/nginx -c /etc/nginx/letsencrypt.conf
fi
/usr/sbin/nginx -c /etc/nginx/letsencrypt.conf -s stop
brahn
(Brahn)
20 באוגוסט, 2018, 10:38am
10
Yeah, not sure what’s going on there. Sorry!
Which indicate it attempts the replace but since it didn’t happen then it must have failed? I don’t know if there is any other diagnostic that can be used to determine success of fail of a pups replacement .
All I can think of is either the replace is not working or you are somehow entering the wrong container? Kind of weird, it all looks ok to me.
CamilleRoux
(Camille Roux)
20 באוגוסט, 2018, 11:15am
11
That’s weird. To be sure, I just need to run ./launcher bootstrap web_pe, right ?
brahn
(Brahn)
20 באוגוסט, 2018, 11:20am
12
What command do you use to enter the container where you ran the cat /etc/runit/1.d/letsencrypt ?
CamilleRoux
(Camille Roux)
20 באוגוסט, 2018, 2:04pm
13
I’m running the following:
$ cd /var/discourse/
$ ./launcher enter web_pe
$ cat /etc/runit/1.d/letsencrypt
Am I wrong?
PS: Here is what I get when I run docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
b3d5c1de8bae 7660254ef762 "/sbin/boot" 5 weeks ago Up 13 hours 0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp web_pe
4f929aed8712 e4dabeee27af "/sbin/boot" 6 weeks ago Up 13 hours data
brahn
(Brahn)
20 באוגוסט, 2018, 2:55pm
14
I cannot see anything that looks wrong!
CamilleRoux
(Camille Roux)
20 באוגוסט, 2018, 3:54pm
15
Ho I found out! Thank you very much for your help.
I needed to run ./launcher rebuild instead of ./launcher bootstrap
