You would also have to check the ecc, but I think it all fits.
yes, that’s how everything should work.
OK. We’re all set. Thanks again for your persistence. I marked you post that points out the problem as the solution.
I already asked in another post if it makes sense to keep the outdated rsa certificate, I hope it will be removed soon.
