Letters getting cut off to the leftmost in posts
I hope none of you recognize me from my last bug report, I have a history of noticing stupid details…
I just noticed that letters are getting cut off to the leftmost in posts. At first I thought I was going crazy, but upon closer inspection it turned out I was somewhat sane.
Have a look at these two letters:
A A
Notice that the left leg of the first A is not quite as thick at the bottom as the left leg of the second? I won’t blame you if you don’t. Here’s a closeup (images captured on the forum of which I am a member):
Now, this is even more noticable if you have a theme with white text
This is so frustrating now that I know it’s there. Hopefully someone clever will be equally frustrated and have a look at it.
The rest of the letters, if you want to have a look at them
A A
B B
C C
D D
E E
F F
G G
H H
I I
J J
K K
L L
M M
N N
O O
P P
Q Q
R R
S S
T T
U U
V V
W W
X X
Y Y
Z Z
7 лайков
Do you see that problem here on or try.discourse.org? Do you see it on that site if you use example.com/safe-mode?
1 лайк
Yep, same thing on here. As you see below it is consistent on all pages. The left A is getting cut off by a pixel.
Same comparison here on the meta:
Comparison on try:
Comparison in safe mode:
4 лайка
Good catch, it’s incredibly slight. Looks as though the overflow: hidden; on .cooked is what’s causing it to be cut off, but I’m not entirely sure why the text would be overflowing by 1px to begin with… will investigate.
12 лайков
Sorry to bump this topic, but I found an example which makes it much clearer what is happening
*j j* becomes
j j
9 лайков
Small update on this, I tested it out a little bit more (in Chrome on Windows 10) and it’s definitely an issue that’s more pronounced on Windows specifically… and if you change the width of your browser window sometimes it happens, sometimes it doesn’t. I don’t really see it on my screen in OSX.
Seems like that would have something to do with subpixel rendering… I think the only way to solve that would be to add a small amount of padding to the left side of .cooked or remove the overflow: hidden (it’s there to protect content like images in deeply nested lists from overflowing the post container, but we might be able to apply it only to the nested containers?)
This issue is a little different. When a font is italicized, it overflows outside of its reserved space (and also its parent div) - so it’s getting cut off by our same overflow: hidden rule.
9 лайков
Закрываю это, так как проблема была исправлена довольно давно. Были и другие проблемы с обрезкой, вызванные overflow: hidden, и это исправление также решило их.
Переполнение всё ещё скрыто, но его положение было изменено, а также добавлены отступы, что даёт тексту немного больше пространства в случаях, когда он естественно немного выходит за границы.
6 лайков
Кстати, у нас похожая проблема с заголовком темы. Смотрите: текущий вариант (#1) против примера без overflow: hidden в h1 (#2)
#1
#2
Мы хотим скрыть переполнение, поэтому лучшее решение, которое я пока придумал, — это добавить комбинацию «положительный отступ, отрицательный отступ» по оси X, чтобы дать ему немного пространства. Но это немного хаковато. @awesomerobot?
7 лайков
Заголовок страницы до прокрутки был исправлен довольно просто. Этот заголовок может переноситься на несколько строк, поэтому свойство overflow было добавлено лишь для предотвращения разрыва длинных слов без пробелов, нарушающих ширину. Убрав overflow и добавив overflow-wrap: break-word;, мы добьёмся переноса слов, когда места недостаточно.
Когда заголовок прилипает к шапке при прокрутке, мы используем overflow: hidden вместе с text-overflow: ellipsis, чтобы обрезать заголовки, превышающие одну строку… убрать overflow там сложнее, поэтому я добавил немного отступов и выровнял по левому краю с помощью отрицательного поля. Это не самый красивый CSS, но работает.
Немного подробнее о том, почему это происходит. В шрифте существует понятие «эмм-бокс» (также называемое «эмм-квадрат»). Эти блоки имеют одинаковый размер для каждого символа и служат основой для масштабирования, настройки межстрочного интервала, межбуквенного интервала и т. д.
Символы могут выходить за пределы эмм-бокса в любом направлении… иногда это необходимо для определённых символов, иногда это просто задумка дизайнера шрифта. В браузере нет способа узнать о существовании такого переполненного контента, поэтому динамически учесть его невозможно.
Насколько мне известно, единственные варианты — избегать переполнения текста, когда это возможно, или добавлять немного дополнительного отступа, когда это сделать нельзя.
6 лайков
