Users are experiencing issues with the lightbox feature not appearing on uploaded images after updating to Discourse 1.9.0.beta13. SlyRemarks first reported the issue, noting that older images work but newer uploads do not. Jomaxro identified that the problem was due to an incomplete update and advised checking the commit version; glynhudson confirmed the fix required a manual update. ravor-org faced a similar issue with a proxy setup, eventually tracing the problem to DNS misconfiguration in their DMZ, which prevented the FastImage library from accessing images via HTTP instead of the local filesystem. Michael_Uray encountered a related DNS issue caused by an incorrectly named app.yml file, which was resolved by renaming it. Daisyliu6 suggested checking image size settings, as images smaller than the thumbnail threshold may not trigger the lightbox.
After the latest update (1.9.0.beta13), our Discourse isn’t displaying images with the lightbox feature (as detailed here); there is no black bar appearing beneath when highlighted. Older images are still showing the lightbox, but newer uploads, either dragged-and-dropped or via the upload menu, are not showing it.
It depends on the exact version you’re on. If you updated to beta13 shortly after its release, you’re likely affected by the bug, and don’t have the fix. Try visiting /admin/upgrade manually and see what commit you’re on. Click the commit number on the left, and see if the fix is in the list of commits shown. If it is, you need to update to get the fix.
I wasn’t able to update via the interface, button was grayed out so I did a manual update:
cd /var/discourse
git pull
sudo ./launcher rebuild app
Thanks a lot for your help. Is there any way to donate a contribution to Discourse? You guys do such amazing work. We have really enjoyed using Discourse
I do have the same problem in my internal discourse instance (running on our own virtualized photonOS+Docker). Any hints you could give to locate the fault? Lightbox is not appearing no matter how I get the picture/image into the post. System was updated today to latest revision although lightbox did never really work.
Thanks for the suggestion. Safe-mode did not work out, Lightbox is still not working.
We indeed have a outer nginx-proxy that is forwarding HTTPS-traffic to the nginx located within the discourse-container (also configured for https). Could that be an issue? If yes, what could be the deal?
Can't reach '/uploads/default/original/1X/858595dc6bfc7699863bfbc35222524c211399c5.png' to get its dimension.
Can't reach '/uploads/default/original/1X/810915fdc059422dfc5337934d2c6b1a9ceef6e0.png' to get its dimension.
So I guess there’s something wrong with uploading the images?
Edit: For sake of completeness: Images are accessible if i just append the path to my domain-name and I do get the full image…
I’ve just moved my docker image from a dedicated server to the outer proxy. The outer nginx is now connecting through sockets instead of forwarding https. Problem still persists. I’m still receiving errors like this (which seem to be issue):
Can't reach '/uploads/default/original/1X/988629194890bf9b48b914c8fe910e15c4ac1d27.jpg' to get its dimension.
The images are valid and accessible, so whats creating the issue here?
EDIT: I’ve dug a little deeper and added some debugging to get_size within the lib/cooked_post_processor.rb and found that this method is acquiring the images by http(s) instead of grabbing it directly from the filesystem. There was an DNS-misconfiguration within our DMZ-setup, so the FastImage lib could not access the files.
Could you extend lib/cooked_post_processor.rb to use the filesystem instead of http(s) if no external location (such as Amazon S3) is used? For my understanding it doesn’t make sense to download the image if it’s already stored on the server already?
DNS внутри образа Docker указывает на его внутренний IP-адрес 172.20.0.6 из сети Docker, а не на внешний публичный IP-адрес, на который фактически настроен домен.
Я обнаружил, что переименовал app.yml в domain.name.yml, и из-за этого Docker изменил DNS-имя domain.name на его внутренний IP-адрес. Я переименовал его теперь в domain_name.yml, и всё работает нормально.
Возможно, проверьте настройки для файлов. Есть настройки для изображений. Проверьте максимальную ширину и высоту миниатюры изображения в публикации. Если изображения меньше этого размера, то в публикации пользователь не сможет на них нажать.
