Hello,
I have added file to “allowed href schemes” but when I create a hyperlink using a file:// url, Discourse will post it with https instead of file.
Then when changing the https back to “file” it’s still opening a https link when clicking on it.
Is the “file” scheme supported in Discourse(I’m in v2.2.0.beta2 +5)?
br
Can confirm that we did not regress completely, adding ftp or steam works. I cannot get file to work, however, though that could just mean I’m doing something wrong. Never used the file href scheme before.
No clue. As mentioned, I’ve never seen the file href before. I used 3 for my screenshot as that’s what I saw over on SO: html - href="file://" doesn't work - Stack Overflow. In any case, I tried 1 (just in case), 2 (normal), 3 (SO answer), 4, & 5 (example in OP) slashes, none worked.
Hi, I’m trying to use local links to PDF documents on local shared network device. I run Discourse locally as a documentation tool. I have tried to add “file” in the href settings, but cannot get a working local link. Is there any way around this? Is this broken or am I doing it wrong?
It’s weird… <a href="file://myfile">link</a> works, but [link](file://myfile) does not. But both options work for other custom schemes as @jomaxro said
Maybe something in the commonmark link internals is stripping out file:// specifically. A quick search doesn’t reveal anything obvious in the discourse codebase.
@user2 the workaround for now is to use the HTML syntax for your link
Edit: even with that, we still have an issue with file:// protocols. It is very common for file paths to start with a / (signifying the root of the filesystem), so the link looks like file:///myfile. Our sanitizer doesn’t like the three slashes at the beginning, and treats the link as invalid.
Opened a file in browser and I see file:///K:/file...., same on windows. But <a href="file://myfile">link</a> does not work either. Maybe it works on *nix based system but not on windows paths?
