spectrum
                    May 27, 2019,  9:43pm
                  1
              Hi there,
    The WP Discourse plugin now has an option to link to Discourse topics without displaying comments underneath the post. This is enabled by selecting the Link to Comments Without Displaying Them option from the plugin’s Commenting settings tab. When you do that, you will find something like this displayed underneath your posts:
[20%20PM]
That doesn’t look great, but you can add some styles to the link by targeting the .wpdc-join-discussion-link class.
[01%20PM]
As comments are added to the Dis…
However, I’m hoping to achieve the same functionality in Drupal.
Is this possible?
                spectrum
                    June 28, 2019,  3:11am
              Just wanted to add a comment to ask if anyone has heard whether this is possible… bump?
              Have you had a look at his?
    Discourse has the ability to embed the comments from a topic in a remote site using a Javascript API that creates an IFRAME. For an example of this in action, check out Coding Horror’s blog . The blog is run via Ghost  but the comments are embedded from his Discourse forum .
One important thing to note with this setup is that users have to navigate to your forum to post replies. This is intentional, as we feel that the posting interface on a Discourse forum is currently much richer than what we …
