When trying to upgrade our Discourse instance, it required a git pull today, but the ./launcher rebuild is failing with FAILED TO BOOTSTRAP and I’m not yet seeing where the failure is coming from.
We’re running Discourse on Ubuntu 18.04. Everything has been going fine up until today’s upgrade.
Our app.yml is called web.yml, so I ran:
# git pull
# ./launcher rebuild web
The tail of the output looks like this:
I, [2022-02-18T19:25:46.155360 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
Discourse requires Redis 6.2.0 or up
I, [2022-02-18T19:25:55.644442 #1] INFO -- : gem install sawyer -v 0.8.2 -i /var/www/discourse/plugins/discourse-github/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Successfully installed sawyer-0.8.2
1 gem installed
gem install octokit -v 4.21.0 -i /var/www/discourse/plugins/discourse-github/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Successfully installed octokit-4.21.0
1 gem installed
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1121 exit 1>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
85459e34ac2c6275dd1700de2c469124a9fded84800b8c6b4686c1c6b66824e2
These are our current plugins:
discourse/docker_manager.git
discourse/discourse-github.git
discourse/discourse-solved.git
discourse/discourse-data-explorer.git
discourse/discourse-akismet.git
discourse/discourse-spoiler-alert.git
cpradio/discourse-plugin-replygif.git
discourse/discourse-push-notifications.git
discourse/discourse-chat-integration
When I scan the launcher output, I’m not seeing the error that’s causing the failure. Any suggestions on what might be causing the failure?
I tried reverting the previous commit to see if I could successfully rebuild our web container without the latest change, but it still fails with a failure to bootstrap. ![]()
Update:
We were using a separate containers setup, which is apparently not a good idea, and our data container was ancient, running Redis v5.0.5 (Discourse currently requires 6.2.0+). So, we rebuilt our data container and then web containers successfully. After this experience, we’ll probably abandon the multiple container approach going forward.
Thanks to @pfaffman for the incredibly helpful links!
