الروابط التي تحتوي على شرطات سفلية محاطة بواصلات يتم عرضها بشكل غير صحيح
I’m not sure if this is a commonmark issue, a markdown-it issue, or a Discourse issue, but when sharing the link in this post, I noticed this edge case with the automatic link detection where the sequence -_foo_- breaks it.
This was the original link:
https://blog.acolyer.org/2018/06/28/how-_not_-to-structure-your-database-backed-web-applications-a-study-of-performance-bugs-in-the-wild/
Here’s a simplified example:
https://example.org/foo-_bar_-baz
And rendered:
(And as an image for good measure):
link-detection-issue-edge-case
As a workaround, to make a link like this go to the right destination, you can always just use a real markdown link like so:
[foo _bar_ baz](https://example.org/foo-_bar_-baz)
foo bar baz
إعجابَين (2)
This was already opened in the context of a Twitter user with similar character patterns in username, rendering linking to that twitter profile very difficult.
إعجابَين (2)
Known issue with commonmark, we can continue discussion here:
