Loading/defining fabricators in plugins
Are there any examples of plugins defining Fabricators?
I found something here that may be relevant: How to lazy load fabricators · Issue #167 · paulelliott/fabrication · GitHub
It says that it clears existing fabricators…
It’s actually quite simple. :slight_smile:
  • add spec/plugin_helper.rb to your plugin if you haven’t got that already.
  • create a folder spec/fabricators and add your factories in there
  • require the *rb files in plugin_helper.rb
I had a need to define custom fabricators in my plugin as well and was surprised that we don’t already have proper support for it.
https://github.com/discourse/discourse/pull/15106
Once the above PR has been merged, your fabricators will automatically be required as long as they exists in the plugin’s spec/fabricators folder.
