תוסף מיקומים 🌍
Sorry @angus I think we’ve just found another bug which is preventing all members from setting or editing a location on their profile.
We are running discourse v2.5.0.beta4 +148 and have changed the Locations plugin to use GitHub - merefield/discourse-locations: Tools for handling locations in Discourse · GitHub which is also at the latest (5185063).
When people edit their profile they now see the standard Discourse location field:
Where before, they would have seen the Locations plugin field:
I’ve tried disabling the plugin from the Admin Settings, then re-enabling it again but that didn’t fix it I’m afraid.
2 לייקים
@angus and if it helps, this error is displayed in the browser console:
Which clicks through to:
3 לייקים
@Richie Thanks Richie. I’ve updated the plugin again to match the latest changes in Discourse (with an assist from @eviltrout).
I won’t be updating this again to keep up with changes in core Discourse until June 1, so if possible please hold on updating your site again till then. If this is an issue, let me know via PM and I can work something out with you.
We’re working on a few different things that will help with the problem of plugin compatibility with Discourse updates. Until we release those, we’re using a time-based approach of updating the plugin to the latest discourse in the first 5 days of every month.
5 לייקים
Fantastic!
Thank you both @angus and @eviltrout this is excellent news.
Installed the update just now, everything is working beautifully again :blush:
Thanks once again guys, loving your dedication and support :+1:t2:
Understood :slight_smile:
4 לייקים
Hi @angus I’m not sure what your update process consists of? Do you just check compatibility against whatever the current version of Discourse core is at the time of the checks?
2 לייקים
Correct. Because the default install of Discourse is tests-passed we update to the latest tests-passed and then perform checks.
3 לייקים
Thanks @merefield I look forward to some more fixes :slight_smile:
2 לייקים
I know we’re not in the 5 day window yet, but just a heads up that todays discourse build is conflicting with this plugin. It is causing the new thumbnails to not work along with causing some other theme components to not work. Here’s the error:
6 לייקים
Yep I’m aware of problems. Oh for a break!
4 לייקים
A break? What’s that?? :grin: :crazy_face: I know the feeling all to well my friend. I appreciate your efforts as always!
4 לייקים
Likewise :bowing_man:
Do you have a beer donation fund @angus @merefield on PayPal or something? We’d love to send you guys a few quid by way of thanks and to keep morale up :beers:
7 לייקים
I figured it out. Locations plugin was causing the conflict with Youtube videos. My three geospatial nerds will be upset, but that’s ok. Safe mode helped. Thanks for that!
3 לייקים
Please do not upgrade at present. I’m doing a major refactor that should be available in next couple of days.
6 לייקים
We noticed this bug yesterday, when I had to upgrade for reasons unrelated to this plugin. In our case, it was either Locations or the Versatile Banner theme component, but not both.
Thank you Robert for your hard work. We can wait, no problem. :slight_smile:
And we’d like to contribute a few euros as well as a grateful Thank You.
5 לייקים
Thanks for your positive comments. ETA still Tomorrow! :mantelpiece_clock: :world_map:
5 לייקים
Hi guys,
I think it conflict with the Table of content component and other component aswell.
if the below screen shot could help you, no rush either, you guys are the best :
Thanks for your support. gros bisous :smiling_face_with_three_hearts:
2 לייקים
I don’t think it’s a clash, it’s a lack of compatibility with current Discourse core as I stated above.
PR in progress.
5 לייקים
Locations remediation PR has been merged:
https://github.com/paviliondev/discourse-locations/pull/50
This took a while as was quite involved.
7 לייקים
@merefield impressive, everything is back, the maps, the theme components, the pictures. Thanks a lot.
4 לייקים
:clap:
Thank you - updating our Discourse to latest now.
Ours is set to this, duly noted, we’ll keep an eye out for updates.
Thanks once again @merefield don’t forget to share details of the beer fund :smiley:
4 לייקים
