תוסף מיקומים 🌍
You will never win. :rofl
If popup is the idea, I prefer the way the map pops up on the topic lists vs in the topics themselves.
The map is now finding my house properly but is getting the zip code and some parts of my address wrong. :facepalm:
לייק 1
Yup this is one of the new features.
Well maybe one day the Topic system will get a makeover …
… now back to making a living :sweat_smile:
לייק 1
תודה שעידכנתי את התוסף. עשיתי רק בדיקה מהירה לאחר העדכון לגרסה החדשה אבל לא ראיתי שום בעיות.
3 לייקים
Displaying all topics on the map with Discourse Location Plugin
Hi everyone,
I’m using the Discourse Location Plugin for my real estate website. I’ve categorized listings by district/street, and each topic is a listing for sale or rent.
I want to display all these topics on the /map page. I’m using the plugin’s default map. However, when I go to a topic to edit and assign a location, the “Find Address” field is frozen.
I’m not sure what I’m missing. Any help would be greatly appreciated!
Thank you! Happy Valentine’s Day!
Hey, I can provide support to businesses who sign up to one of my GOLD or PLATINUM monthly Sponsorship tiers.
There is also a one-off bug hunt option.
3 לייקים
Robert, quick issue when running qunit tests unrelated to this plugin. It makes the tests fail.
I think writing custom_fields?.location_enabled should be enough.
2 לייקים
Sure, np,
https://github.com/merefield/discourse-locations/commit/7eb7be3f823927d4f65e6cbad60d8665c86ae2a2
5 לייקים
Sorry Robert, actually I missed an occurrence. Should be the last:
https://github.com/merefield/discourse-locations/pull/121
2 לייקים
I used this code to add the location below the topics titles on the topic list:
javascripts/discourse/connectors/topic-list-after-title/topic-list-after-title.hbr
{{#if context.topic.location}}
  <br>
  <span class="title-location">
    {{d-icon 'map-marker-alt'}} {{location-format context.topic.location opts}}
  </span>
{{/if}}
It won’t work soon, if someone has an idea how to make it compatible with the recent version :slight_smile:
לייק 1
Not sure you need that anymore. It’s added below the title now.
2 לייקים
I’m a bit puzzled. It works on Achats - Monocycle.info
But not on Trading Post - Unicyclist.com
(there are locations set on almost every topic)
Here are the modified settings on the first link
And the 2nd:
The location-related category settings are the same for both sites.
Can’t figure out why the locations don’t appear on unicyclist.com, tho I’m sure I just missed something obvious.
https://unicyclist.com/c/trading-post/18?safe_mode=no_themes
It looks like a TC interferes with the plugin here.
2 לייקים
Yeah, I had removed the standard location icon a long time ago so I could override it with my own location component (I’m sure I had a very good reason for this :nerd_face:), and I forgot to revert this back after deleting my custom component.
Thanks for the help :hugs:
3 לייקים
And what is more, those locations are now clickable and will pull up the map :earth_africa: :rocket:
3 לייקים
btw, on the topic of “maps” I highly recommend you (and other users of the plugin) explore the different maps available via the link in the settings:
the default one has high utility but a bit … colourless.
לייק 1
@Canapin I just happened to browse your forum.
NB if you don’t fully Geolocate your locations, you will end up with this.
Washington is showing as one big map with no pointer.
It should be more like this:
Yeah, I know but I don’t feel like educating my users about it (I think most will only post once in the trading post category :smile:) nor edit each location myself each time a new topic is created
I noticed this, the new posts dot is not properly aligned with the topic’s title on the topic list :slight_smile:
לייק 1
Looking forward to your PR :wink:
If not, I’ll look at it soon.
PS for most use cases, I’m not convinced this plugin connector is useful … it really should be after the badge. I’ll look at switching it.
Fixed:
https://github.com/merefield/discourse-locations/commit/daebecb33a4f269b18fbb9eb5608c625ef356056
https://github.com/merefield/discourse-locations/commit/a0bdb1f440d7ccfb1859773f6f39878e8bd398fb
Cheers.
5 לייקים
ניסיון בפעם הראשונה עם תוסף זה בסביבת הפיתוח המקומית שלי והבחנתי בבעיות מסוימות. כשאמצא זמן, אנסה לעבוד על שאילתה משופרת.
בעת עריכת נושא להוספת מיקום, ה-TopicLocation לא נוצר, ולכן הוא לא מופיע על המפה. נראה שזה נובע מבעיית ניתוח מחרוזת ה-location שהותאם אישית בתחום המידע של השדה (custom_field).
בעת צפייה בקטגוריה, המיקומים לא מופיעים ברשימת הנושאים, בשל השימוש במכון “לפני הקטגוריה” (אין מכון כזה בעת צפייה ברשימת נושאים בקטגוריה). בנוסף, ה-location_topic_status כנראה לא משמש בשום מקום.
4 לייקים
