I just want to ask if anyone can reproduce it or is it happening just to my discourse forum… When I activate the option in admin section Login Requiered, and when an User logs in, after sucessfull login the discourse forwards him to the page: example.org/menu_links . This menu_links page does not exist. Shouldn’t discourse go to the main domain (example.org/) strait away? How come this /menu_links apears?
I’ve done what you suggested. I deactivated plugins one by one and found out that discourse-navigation plugin was faulty when Login Required option in admin section is activated. It is also reported to developer on his github repo..
I hope that it would be fixed soon.. because I find it esential to have…
Hi @arnie, “discourse-navigation” plugin is currently not in active development. Like in your screencast if you want to add icon links in header then use Custom Header Links (icons) theme component.
Thank you @vinothkannans for pointing on that alternative, but specifically I used your plugin for creating a couple of footer links in hamburger drop-down-menu, and I think this addon theme does not support that functionality. Okay for now I’ll search for alternative way. Thanks
