The login page isn’t responding anymore? If I edit and save new text, only old text is visible.
Discourse - latest version
I just tried customizing the login_required.welcome_message
text on my site and it’s working for me.
When you edit and save the text are you seeing any errors? Does the saved text show up when you search for login_required.welcome_message
at Admin / Customize / Text Content?
Yes, I’m sure it’s being saved; the text is visible in the admin panel, but not on the index page. Reverting the setting doesn’t work either.
No error message
You might need to customize login_required.welcome_message_invite_only
if your forum is requires login and is invite only.
Excellent. Thank you, again
