The discussion addresses a login screen alignment issue on screens smaller than 640px. Jack_McCarthy reports that the mobile login is left-aligned instead of centered, and attempts to fix it via margin adjustments inadvertently affected the main page. After testing, they identify 640px as the cutoff point where the issue occurs. pmusaraj suggests the problem may stem from a CSS rule limiting the width of #main-outlet, which is likely in the Horizon theme. Jack_McCarthy confirms this, explaining that they were adjusting the #main-outlet width to reposition the sidebar, inadvertently causing the login screen misalignment. The issue is tied to theme-specific styling rather than a core bug.
I think there is a CSS rule here that limits the width of #main-outlet. I suspect it’s in your custom theme. When I use Horizon (this is based on Horizon, yes?), I don’t see the same issue.
I am using Horizon, sorry I forgot to mention that. I was limiting the main-outlet width to make room to nudge the sidebar over so it wasn’t hugging the edge of the screen.
I reverted those changes so now the login screen takes up 100% of the screen like it’s supposed to. Sidebar has to touch the edge of the screen now but that’s not nearly as bad of an issue.
