Are there any plans for integrating Telegram Login as an OAuth provider? Or someone that could do a plugin?
It has been released today, I tested and it’s really practical:
To be precise it’s not an implementation of the oauth protocol. Very interesting anyway.
By the way, I’ve implemented Discourse SSO provider for Telegram Login, basing on the code from my SAML SSO provider:
Also available from DockerHub, docker pull kirushik/discourse_telegram_auth.
Currently it’s completely untested, and lacks any documentation — but bugreports and feature requests are welcome.
Any preview or demo?
Well, it’s available on the forum I’ve written it for — but it’s a special-interest group in Russian, so I don’t think sharing it here will be a good idea.
Meanwhile, using Telegram as SSO provider is not what most people want — so I think I’d spend some time turning my code in a proper auth plugin…
It would be great if something like that could be implemented. I.e. login/signup on Discourse site thru telegram.
I’ve found that normal users are not able to login/signup to my forum simply because they never remember their emails ID and PWs. They just get someone to create an email account when they setup their new android phone, and then afterwards they never sign out or sign in to the same.
Any progress there, just in case?
I was interested in making our site users to be able to create account and login thru telegram. This way they can dispense with email id/pw, and can create account and login with just their mobile number (and telegram app).
Anche io sono curioso a riguardo. Qualcuno lo ha configurato con successo? Vedo che entrambi i fork non hanno ricevuto aggiornamenti da aprile 2018.
Sarebbe fantastico vederlo funzionare, abbiamo oltre 200.000 iscritti su Telegram e questo ci aiuterebbe moltissimo.
Adoro questo progetto, sta ancora andando bene?
Beh, il codice è ancora lì e non dovrebbe esserci nulla di rotto al suo interno (a parte le dipendenze obsolete e potenzialmente vulnerabili).
Tuttavia, non credo più che abusare delle API SSO di Discourse per l’accesso con Telegram sia la strada giusta da percorrere (ecco perché il repository è archiviato).
Una soluzione molto migliore sarebbe un plugin che aggiunga un pulsante Telegram alle opzioni di autenticazione supportate nella finestra di accesso/schermata di login — ma questo richiederebbe un approccio piuttosto diverso, e non sono a conoscenza di qualcuno che stia cercando di farlo (anche se è assolutamente possibile, e ricordo di aver visto altri plugin con funzionalità simili che utilizzano altre reti di login da qualche parte).
Ho una v1 funzionante qui:
@mjsir911 intendi continuare a lavorare su questo plug-in? Oltre ai problemi menzionati nella repository di GitHub, sarebbe fantastico poter recuperare l’uniqueid e non il campo Name, e il nome utente. Utile per un futuro flusso. Posso impostarlo come lavoro nel Marketplace se qualcuno è interessato.
Ciao! Voglio ringraziare @mjsir911 per il plugin tanto necessario e meraviglioso ![]()
Sono d’accordo con te @Mr.X_Mr.X. Volevo anche chiedere a @mjsir911 come posso rimuovere la riga per l’inserimento dell’indirizzo email durante la registrazione tramite un bot Telegram? Nel mio caso, ho scelto questo plugin in modo che le persone non debbano passare attraverso passaggi aggiuntivi (soprattutto l’inserimento del loro indirizzo email) per registrarsi. Quando stavo per installare questo plugin, ero sicuro che l’email non sarebbe stata richiesta ![]()
Ci sono riuscito! ![]()
Ma, quando clicco su “Accedi con Telegram” su Discourse, vengo reindirizzato a mysite.com/auth/telegram - e si presenta così:
Sai se quel sito è impostato dal plugin o cosa? Non posso nemmeno modificare il CSS, dato che la pagina è al di fuori dell’ambito dei temi…
Sta ancora funzionando? Non vedo più il pulsante di accesso
Ho problemi a far funzionare questo, qualcuno può aggiornare se funziona?
Ciao a tutti, ho provato anche io a riprogettare il plugin, ma senza successo.
Anche questa vecchia versione del plugin non funziona.
Credo che dovrò trovare qualcuno che lo scriva da zero…
Per me è fondamentale che tutti gli account abbiano l’autorizzazione obbligatoria e il login confermato tramite Telegram. Se qualcuno conosce la soluzione, per favore, scriva.
