When the content of an answer is long enough, and wrapped in <code>
, it renders outside the answer box:
I attempted to verify this at try
, but the Solution plugin isn’t enabled:
Looks like a dublicate of Long words in embedded solutions aren't wrapped
@Moin, I agree. If the solution plugin were enabled here, I’d mark your comment as it.
It is. But not in the Bug category. It’s enabled in Support, Dev, Installation, and Data & reporting.
@Moin, thanks. Suggested:
