Looking to hire Dev to help with custom theme and config
The original poster is looking to hire a developer to help with custom theme and configuration setup for their company’s platform, with a budget of $20-40/hr and an ASAP deadline. 0xReal asked for clarification on the requirements. pfaffman suggested using the Literate Computing Dashboard, a fully automated installation tool with email support, which can complete the setup in about 30 minutes with quick DNS configuration. crcoli7307 found this recommendation helpful and noted that Cloudflare makes DNS configuration easy. Ahmed_Gagan expressed interest in taking on the task.
What would you like done?
I need help setting up the platform for our company.
When do you need it done?
ASAP
What is your budget, in $ USD that you can offer for this task?
$20-40 hr
Hey David. The Literate Computing Dashboard (https://dashboard.literatecomputing.com/) will do the installation for you. It is fully automated, with email support if you get stuck.
If you’re quick with DNS configuration, it takes about 30 minutes.
Hi David,
I am interested to take this up, sending you a PM
Luckily, Cloudflare makes DNS configuration really easy.
I didn’t know this existed! Will definitely look into recommending this to others who need help with their discourse install.
