Hello!
We’re running into a problem with too many emails being sent per day. We have about 90-100 daily active users, but around 1k emails are being sent per day. I’m assuming it’s coming from daily digest? Is there a way to globally change that to weekly? Also, any other tips on how to lower the amount of emails being sent daily?
Thanks,
Callahan
Looking at admin > email > sent might give you a quick idea of where most emails are coming from…
In terms settings to potentially reduce emails:
If you go to admin > settings you can search for default email digest frequency and change that value.
You can also try lowering max emails per day per user
It might be worth checking if any of the mailing list mode settings are enabled? Those would generate a lot of emails. You can also prevent users from turning on mailing list mode in their preferences with the disable mailing list mode setting.
12 个赞
