This is a little weird it basically means all launcher commands are now disallowed as container names? Not that matching names isn’t confusing anyway, I grant you that…
No, I don’t see why this would mean that launcher command names are disallowed as container names: If the first parameter is a valid command, behavior will be the same as it is now. And if the first parameter is not a valid command, the current behavior is to exit 1 with an error message.
My PR only addresses the case where the first command is not a valid command name and the second command is a valid command name. In this case, it is probable that the user confused the parameter order.
For the sake of safety, we could prompt the user:
$ launcher app build
'app' is not a valid command name.
Did you mean 'launcher build app'? [Y/n]
PS: Interesting: The first line (GitHub - discourse/discourse_docker: A Docker image for Discourse · GitHub) links to the commit (= url that i posted here), whereas the subject line (FEATURE: Make launcher forgive swapped parameters) links to the PR. I’m sure that’s intended, but that just surprised me.
Nothing against making things more user friendly, but most of the few CLIs I’ve used simply output a type of > enter --help when I’ve used the wrong syntax.
“Nothing against” and “but” don’t work well together, so let me say this: Most of the few forum softwares I’ve used weren’t very usable, so why making Discourse a usable forum software?
I don’t know what you mean by that other than you must have misinterpreted what I meant it to say.
I did not mean that the code should not correct user error.
Simply that most CLIs detect user error and “point them in the right direction” instead of trying to correct it for them.
If it is easy enough to accept command arguments and options in different sequences, different grammar (eg. ./launcher -r -a), then yes, it should be done.
Es tut mir leid, aber wir haben diesen PR nun seit 3 Jahren liegen… und hier bin ich, ihn nach 3 Jahren abzulehnen.
Meine Begründung für diese Ablehnung ist, dass unser riesiger Bash-Ball bereits so fragil und komplex ist. Ich möchte beim Hinzufügen neuer Dinge hier äußerst vorsichtig sein, und dies wäre ein weiterer Punkt der Fragilität, um den wir uns kümmern müssten. Wir müssten diesen Abschnitt aktualisieren, sobald wir neue Befehle hinzufügen.
