I am suddenly getting the following error on launcher rebuild. These are for discourse instances that have been running for years without a problem and the YAML file is untouched from the last time that rebuild worked successfully to update discourse. Any help would most sincerely be appreciated.
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 10 app
app
cd /pups && git pull && /pups/bin/pups --stdin
/usr/bin/docker: invalid reference format: repository name must be lowercase.
See '/usr/bin/docker run --help'.
cat: cids/app_bootstrap.cid: No such file or directory
"docker rm" requires at least 1 argument.
See 'docker rm --help'.
Usage:  docker rm [OPTIONS] CONTAINER [CONTAINER...]
Remove one or more containers
rm: cannot remove 'cids/app_bootstrap.cid': No such file or directory
Also I tried to look in /pups and it indicates there is no such directory?
I am able to get the discourse instance back up and running by simply starting the container again.
