chapel
(Jacob Chapel)
18 januari 2015 om 07:16
1
Continuing the discussion from How to re-generate all topics? :
Hi. I’ve updated lazyYT plugin with the following data:
- replace:
filename: /var/www/discourse/plugins/lazyYT/plugin.rb
to: data-ratio=\"16:9\"
Now I need all the topics to pick up changes (manual edit+save works fine). Is there an easy way of doing it in console?
I had wanted to do similar, but found a simpler way of implementing what I wanted without messing with the ruby files.
Specifically this will make all embedded lazyYT Youtube videos responsive and 16:9 taking up most of the post width.
Add the following snippet to your Customize CSS section:
.lazyYT {
height: 0 !important;
width: 100% !important;
padding-bottom: 56.25% !important;
Remember anything that makes height of posts change dynamically will eventually screw up stream positioning, depending on how many posts in the stream have this happening. Worst case every one of them, e.g. a “post cool videos” topic.
chapel
(Jacob Chapel)
18 januari 2015 om 09:02
3
It doesn’t change anything dynamically, as the style is always applied and overrides whatever is set by default from lazyYT.
When I say it is responsive, is that it uses the full width of the post div.
Keep in mind that the above CSS is essentially the same CSS that is added by lazyYT when you set the aspect ratio to 16:9.
https://github.com/discourse/discourse/blob/master/plugins/lazyYT/assets/javascripts/lazyYT.js#L18-L29
It uses padding-top instead of bottom though.
Thanks. I’ll stick with my changes to plugin.rb for now, but I’ll keep in mind there’s another way to do it.
chapel
(Jacob Chapel)
18 januari 2015 om 18:57
5
Yeah understandable. Just saw that someone else (you) wanted to do the same thing so I shared with everyone how I solved it since its easy to do.
dbm
7 februari 2015 om 17:47
6
Works fine, thanks @chapel
elberet
(Jens Maier)
10 februari 2015 om 19:46
7
Thanks for that top, but I had to modify your CSS slightly:
.lazyYT {
In my case, the lazyYT JS generated a style attribute with width: 480px and padding-bottom: 270px; stylhes, but no height.
chapel
(Jacob Chapel)
10 februari 2015 om 20:10
8
Ah, so I had to update that as well but forgot to update this. Will update the OP.
bts
(Brendan Schlagel)
8 februari 2018 om 23:04
9
This is great, thanks!
@techAPJ may be worth integrating these few lines of CSS into the plugin, seems like a really nice improvement for YouTube embeds.
