Hi Christoph. Sorry for not answering earlier. Good to know you figured it out. Admittedly, it’s not a very intuitive plugin. An admin UI would go along way towards making it more usable.
This can probably be closed now, although…
One feature I’m missing is the ability to change these settings via a category’s own settings. I went looking for this setting when a customer requested it, and the first place I looked was the settings screen of a specific category.
Has this been added as core functionality?
If you’re referring to the ‘default categories watching’ setting and it’s cousins, then yes, it’s in core.
I’m not sure what the cousins you’re referring to are, but the default categories watching setting doesn’t accomplish the OP’s goal:
I don’t just mean there’s no UI like that. AFAIK, the only way to get a specific group (not all users) to “watch” (or “watch first post” or whatever) a specific category – and to have that happen after the user has been created – is by using a plugin, such as the one I use.
I’d be happy to ditch this workaround, but I don’t see this functionality in core. Or have I missed something in a recent update?
I don’t see in this thread whether staff have answered the question if they agree this feature should be in core. Knowing if it’s in the pipeline or not would help.
I created an RFC for the implementation side of this a while back (I’m sure I linked to it somewhere in this thread):
But it looks like the consensus is for implementing this as a plugin. That’s something I plan to do at some point, but I can’t say when.
@LeoMcA is this something you got around to doing in the end?
Not yet, I’ll post in that other thread when I do ![]()
There are a couple plugins that do this that require a bit of customization to work. One is linked above. If it won’t work for you and you have a budget, feel free to contact me.
@pfaffman, interested in what plugin you might recommend. Are you referring to this one?
Yes. That’s one that I’ve modified. I modified it find all groups matching a pattern, and then find categories with similar names and force watching for those.
Very cool. If all we want to do is force watch 2-3 Categories for 2-3 Groups, the plug in will work out of the box?
Is there any documentation on it, or is it self-explanatory once installed?
No, it won’t work out of the box. You need to fork it on Github and modify the plugin.rb file so that it matches your groups and categories. Then you install your modified version.
Nope. If you know any programming, you might be able to make sense of the code. If not, and you have a budget, you can post in marketplace, or contact me directly. My contact info is in my profile.
Ok, Jay. We’ve certainly valued your work in the past, so will ping you if we need further assist!
Thanks, Christoph. We’ll have a look!
@kimardenmiller I use this plugin, which I developed from the ones mentioned here:
https://github.com/amical/discourse-watch-category
If you can fork that plugin on GitHub, I can help you customize it. ![]()
Nice Alex. Looks as if you have nicely parameterized it with the groups_cats dictionary.
Just edit those for Watching vs. Watching First Post, then just edit the frequency at the end?
Anything else to know?
Nope, you got it!
Holler if you run into trouble.
I needed that, but as a one shot feature. What I did is (based on the code of this plugin) to run a few lines of code from the rails console:
from your discourse folder
./launcher enter app
root@application-app:/var/www/discourse# rails c
[1] pry(main)>
Once you are on the rail console:
## customise to what you want
g = Group.find_by_name('your_group')
c_id = Category.find_by_slug('you_category_slug').id
pref=:watching_first_post
g.users.each do | user |
existing = CategoryUser.lookup(user, pref).pluck(:category_id)
CategoryUser.set_notification_level_for_category (user, CategoryUser.notification_levels[pref], c_id) unless existing.include?(c_id)
Hope it helps someone
