Make TL3 100 days a changeable Setting?
A discussion on making the 100-day time frame for reaching Trust Level 3 (TL3) a changeable setting. Mittineague proposed this idea, suggesting it would be beneficial to have a customizable “prove yourself” time frame, rather than a hardcoded 100 days. This would allow sites to adjust the period to suit their specific needs. codinghorror supported the idea, and techAPJ has since implemented it as a site setting.
Continuing the discussion from Agreeing/Deferring/Disagreeing with Flags:
I’m just thinking out loud here, but I’m wondering if it could be done fairly easily if the hard coded “100 days” that the Trust Level 3 requirement settings use might be better as a kind of “time period” setting.
I have a feeling that the status quo works fine as is for most cases, but I can’t help thinking it might be better if it could be tweaked to shorter or longer “prove yourself” time frames.
True, a member’s TL can be locked, but just the same.
「いいね!」 2
Sure, I can support that being a site setting, @techapj can you add that to your list?
「いいね!」 2
Done :gift:
https://github.com/discourse/discourse/commit/f40249faad16aae54357c23f47bd409f0f10c6dd
「いいね!」 3
